    Padrão O que pode estar causando estes erros?
    Olá meu servidor está rodando o slackware com 2 hd scsi e 1 ide, porém estou sem instabilidade no servidor. O cache estava rodando no scsi 2. Abaixo segue os erros do syslog.
    Jun 7 21:01:54kernel: ipt_unclean: UDP zero destination port
    Jun 7 21:01:54last message repeated 9 times
    Jun 7 21:40:56kernel: is_leaf: item location seems wrong (second one): *3.6* [3 126 0x0 SD], item_len 1580, item_location 2732, free_space(entry_count) 65535
    Jun 7 21:40:56kernel: sd(8,17):vs-5150: search_by_key: invalid format found in block 31551. Fsck?
    Jun 7 21:40:56kernel: sd(8,17):vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [3 126 0x0 SD]
    Jun 7 21:40:57kernel: is_leaf: item location seems wrong (second one): *3.6* [3 174 0x0 SD], item_len 1580, item_location 1892, free_space(entry_count) 65535
    Jun 7 21:40:57kernel: sd(8,17):vs-5150: search_by_key: invalid format found in block 107377. Fsck?
    Jun 7 21:40:57kernel: sd(8,17):vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [3 174 0x0 SD]
    Jun 7 21:40:58kernel: is_leaf: item location seems wrong (second one): *3.6* [3 126 0x0 SD], item_len 1580, item_location 2732, free_space(entry_count) 65535
    Jun 7 21:40:58kernel: sd(8,17):vs-5150: search_by_key: invalid format found in block 31551. Fsck?
    Jun 7 21:41:00kernel: is_leaf: item location seems wrong (second one): *3.6* [3 174 0x0 SD], item_len 1580, item_location 1892, free_space(entry_count) 65535
    Jun 7 21:41:00kernel: sd(8,17):vs-5150: search_by_key: invalid format found in block 107377. Fsck?
    Jun 7 21:41:01kernel: is_leaf: item location seems wrong (second one): *3.6* [261 343 0x0 SD], item_len 1580, item_location 3212, free_space(entry_count) 65535
    Jun 7 21:41:01kernel: sd(8,17):vs-5150: search_by_key: invalid format found in block 8563. Fsck?
    Jun 7 21:41:01kernel: sd(8,17):vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [261 343 0x0 SD]
    Jun 7 21:41:03kernel: is_leaf: item location seems wrong (second one): *3.6* [261 343 0x0 SD], item_len 1580, item_location 3212, free_space(entry_count) 65535
    Jun 7 21:41:03kernel: sd(8,17):vs-5150: search_by_key: invalid format found in block 8563. Fsck?
    Amigo isso ae é problema em seu HD Scsi pelo jeito, ele não está conseguindo localiizar os inodes corretamente, isso pode ser devido há algum tipo de bad block no seu disco, ou algum corrompimento de arquivo. te aconselho a uma hora parar esse servidor e rodar o fsck nas partições do seu disco e realizar um teste de escrita e leitura no seus hds, agora se não tiver tempo de fazer isso, troca eles. solução mais rapida e aconselhavel.
    Mas uma pergunta essa maquina sofreu algum tipo de parada de energia brusca. ou queda momentanea do servidor.
    Parece ser problemas no hd mesmo.
    Ja tentou ligar ele em outra maquina ?
