    Post ldap autenticação de usuários
    Boa Tarde!,
    Pessoal tenho um servidor Debian com LDAP e estou querendo que meu proprio servido se logue no ldap como outras maquinas em linux, quando um
    usuário tenta logar no cliente e este tenta autenticar no servidor ldap recebe
    erro no login do usuário, como
    error trying to bind as user "uid=teste,ou=Usuarios,dc=flexit,dc=intra" (Invalid
    Credentials)
    o que pode ser isso e como posso solucionar ? Algumas pessoas achavam qeu é
    o pam das estações clientes, mas se for como posso resolver.
    /etc/ldap.conf
    HOST 192.168.0.5
    URI ldap://192.168.0.5
    PORT 389
    BASE dc=flexit, dc=intra
    BINDDN cn=admin, dc=flexit,dc=intra
    BINDPW 123456
    SIZELIMIT 12
    TIMELIMIT 15
    DEREF never
    nss_base_passwd ou=Usuarios,dc=flexit,dc=intra?one
    nss_base_shadow ou=Usuarios,dc=flexit,dc=intra?one
    nss_base_group ou=Grupos,dc=flexit,dc=intra?one
    /etc/ldap/ldap.conf
    HOST 192.168.0.5
    PORT 389
    BINDPW 123456
    SIZELIMIT 12
    TIMELIMIT 15
    DEREF never
    /etc/nsswitch.conf
    passwd: files ldap
    group: files ldap
    shadow: files ldap
    hosts: files dns
    networks: files
    protocols: db files
    services: db files
    ethers: db files
    rpc: db files
    netgroup: nis
    tail /var/log/auth.log
    Jun 19 11:55:17 max sshd[2279]: (pam_unix) session opened for user root by root(uid=0)
    Jun 19 11:55:42 max login[2210]: (pam_unix) session opened for user root by LOGIN(uid=0)
    Jun 19 11:55:42 max login[2210]: ROOT LOGIN on `tty1'
    Jun 19 11:56:02 max login[2292]: (pam_unix) session opened for user peregrino by LOGIN(uid=0)
    Jun 19 11:56:08 max login[2337]: pam_ldap: error trying to bind as user "uid=teste,ou=Usuarios,dc=flexit,dc=intra" (Invalid credentials)
    Jun 19 11:56:08 max login[2337]: (pam_unix) check pass; user unknown
    Jun 19 11:56:08 max login[2337]: (pam_unix) authentication failure; logname=LOGIN uid=0 euid=0 tty=tty1 ruser= rhost=
    Jun 19 11:56:11 max login[2337]: FAILED LOGIN (1) on `tty1' FOR `teste', Authentication service cannot retrieve authentication info.
    Jun 19 12:09:01 max CRON[2455]: (pam_unix) session opened for user root by (uid=0)
    Jun 19 12:09:01 max CRON[2455]: (pam_unix) session closed for user root
    tem alguma coisa na minha configuração ou esta faltando algo se alguem souber me da uma luz
    obrigado
    Bom dia Peregrino.
    O pam esta chegando ao servidor ldap sem problemas, essa causa esta' eliminada. O seguinte log nos diz basicamente duas coisas:
    Primeiro: o cliente conseguiu conexao com o servidor ldap, caso contrario, teria dado erro referente a falha na conexao.
    Segundo: as credenciais nao sao validas, ou o usuario nao existe, ou a senha nao e' valida, ou as acls no servidor ldap nao estao permitindo autenticacao, verifique se tem uma acl mais ou menos como a seguinte;
    access to *
    by * read
    by self write
    by users read
    by anonymous auth
    Verifique a questao do usuario e senha.
    Abracos.
    Fabio K. Lima
    LPIC
    Post
    Bom Dia !
    Fabio K. Lima obrigado pela ajuda mas eu consegui era problema na senha do usuario
    agora gostaria de te perguntar sobre postfix+ldap por exemplo
    eu sei que para fazer o aliases ficar na base de dados ldap tenho que colocar a linha no meu main.cf
    alias_maps = ldap:/etc/postfix/aliases-ldap.conf
    e dentro colocar
    server_host = 192.168.0.5
    server_port = 389
    search_base = ou=Usuarios,dc=submundodigital,dc=com
    query_filter = (&(objectClass= posixAccount)(mail=%s))
    result_attribute = maildrop
    dn = cn=admin,dc=submundodigital,dc=com
    dnpass = 123456
    version = 3
    gostaria de saber o seguinte
    quando uso em hash tenho que usar o comando postmap aliases e no site do postfix vi que quando uso com ldap tenho que fazer
    postmap -q [email protected] ldap:ldap-aliases.cf [email protected],[email protected]
    mas não funciona
    obrigado
