- Erro de login
Erro de login
E ae galera Under-linux!!!
Queria dar um oi ae a galera pq é meu primeiro post!!!
Indo para o assunto
tenho um freebsd 6.0 rodando o samba 3 /usr/ports/net/samba3/
instalei normal tudo blz....
configurei o smb.conf tudo blz...
mais depois que botei netbios name = Servidor e entre no grupo de trabalho ae reiniciei o windows e nao consigo logar de jeito nenhum no samba
meu smb.conf
[global]
# workgroup = NT-Domain-Name or Workgroup-Name, eg: MIDEARTH
workgroup = ANDERSON
# server string is the equivalent of the NT Description field
server string = Anderson Samba
security = user
; hosts allow = 192.168.1. 192.168.2. 127.
; printcap name = /etc/printcap
; printcap name = lpstat
; printing = cups
; guest account = pcguest
log file = /var/log/samba/log.%m
max log size = 50
; password server = <NT-Server-Name>
; realm = MY_REALM
; passdb backend = tdbsam
; include = /usr/local/etc/smb.conf.%m
; socket options = SO_RCVBUF=8192 SO_SNDBUF=8192
interfaces = 192.168.190.0/24
; local master = no
; os level = 33
; domain master = yes
; preferred master = yes
; domain logons = yes
; logon script = %m.bat
; logon script = %U.bat
; logon path = \\%L\Profiles\%U
; wins support = yes
; wins server = w.x.y.z
; wins proxy = yes
dns proxy = no
; display charset = koi8-r
; unix charset = koi8-r
; dos charset = cp866
; store dos attributes = yes
; map hidden = no
; map system = no
; map archive = no
; nt acl support = yes
; inherit acls = yes
; map acl inherit = yes
; add user script = /usr/sbin/useradd %u
; add group script = /usr/sbin/groupadd %g
; add machine script = /usr/sbin/adduser -n -g machines -c Machine -d /dev/null -s /bin/false %u
; delete user script = /usr/sbin/userdel %u
; delete user from group script = /usr/sbin/deluser %u %g
; delete group script = /usr/sbin/groupdel %g
#[homes]
# comment = Home Directories
# browseable = no
#writable = yes
#[printers]
# comment = All Printers
# path = /var/spool/samba
# browseable = no
# Set public = yes to allow user 'guest account' to print
# guest ok = no
# writable = no
# printable = yes
[Usr]
path = /usr/local/etc/
public = yes
writable = yes
printable = no
create mask = 0777
[anderson]
comment = Anderson Config's
path = /anderson
valid users = anderson leo
public = no
create mask = 0777
blz!!
Olá,
Antes de voce colocar o netbios name, voce chegou a conseguir abrir um dos compartilhamentos que voce fez, a partir da maquina windows?
Antes do netbios e de entra no grupo de trabalho funcionava tudo normal!!!
agora nao loga nem a pau!!!
adicioano usuario assim:
adduser nome_do_usuario
preencho tudo normal
depois
smbpasswd -a nome do usuario
e nao funfa de jeito nenhum!!!
depois de descomentei essa linha funcionou!!!
aproveitando que já está no assunto, queria fazer para toda vez que o cliente abrir o compartilhamento ter que logar de novo, pq assim se logar uma vez nao precisa logar de novo!!!!
blz!!!
