    Padrão Travamento temporário?!?!?!
    Oi galera...será que alguém faz idéia do que é isso?
    ################ KERN.LOG #################
    Jul 29 03:12:26 localhost kernel: oom-killer: gfp_mask=0x200d2, order=0
    Jul 29 03:12:26 localhost kernel: [<c014457b>] out_of_memory+0x25/0x13e
    Jul 29 03:12:26 localhost kernel: [<c01459e8>] __alloc_pages+0x1f5/0x275
    Jul 29 03:12:26 localhost kernel: [<c0151bbe>] read_swap_cache_async+0x2f/0xac
    Jul 29 03:12:26 localhost kernel: [<c014affa>] swapin_readahead+0x3a/0x58
    Jul 29 03:12:26 localhost kernel: [<c014c3c1>] __handle_mm_fault+0x4db/0x740
    Jul 29 03:12:26 localhost kernel: [<c01154b6>] do_page_fault+0x18a/0x481
    Jul 29 03:12:26 localhost kernel: [<c011532c>] do_page_fault+0x0/0x481
    Jul 29 03:12:26 localhost kernel: [<c01037f9>] error_code+0x39/0x40
    Jul 29 03:12:26 localhost kernel: Mem-info:
    Jul 29 03:12:26 localhost kernel: DMA per-cpu:
    Jul 29 03:19:53 localhost kernel: cpu 0 hot: high 0, batch 1 used:0
    Jul 29 03:19:53 localhost kernel: cpu 0 cold: high 0, batch 1 used:0
    Jul 29 03:19:53 localhost kernel: cpu 1 hot: high 0, batch 1 used:0
    Jul 29 03:19:53 localhost kernel: cpu 1 cold: high 0, batch 1 used:0
    Jul 29 03:19:53 localhost kernel: DMA32 per-cpu: empty
    Jul 29 03:19:53 localhost kernel: Normal per-cpu:
    Jul 29 03:19:53 localhost kernel: cpu 0 hot: high 186, batch 31 used:31
    Jul 29 03:19:53 localhost kernel: cpu 0 cold: high 62, batch 15 used:49
    Jul 29 03:19:53 localhost kernel: cpu 1 hot: high 186, batch 31 used:6
    Jul 29 03:19:53 localhost kernel: cpu 1 cold: high 62, batch 15 used:14
    Jul 29 03:19:53 localhost kernel: HighMem per-cpu:
    Jul 29 03:19:53 localhost kernel: cpu 0 hot: high 186, batch 31 used:12
    Jul 29 03:19:53 localhost kernel: cpu 0 cold: high 62, batch 15 used:52
    Jul 29 03:19:53 localhost kernel: cpu 1 hot: high 186, batch 31 used:30
    Jul 29 03:19:53 localhost kernel: cpu 1 cold: high 62, batch 15 used:25
    Jul 29 03:19:53 localhost kernel: Free pages: 48956kB (472kB HighMem)
    Jul 29 03:19:53 localhost kernel: Active:236778 inactive:237744 dirty:0 writeback:0 unstable:0 free:12239 slab:4259 mapped:237 pagetables:2590
    Jul 29 03:19:53 localhost kernel: DMA free:8160kB min:68kB low:84kB high:100kB active:5332kB inactive:0kB present:16384kB pages_scanned:8969 all_unreclaimable? yes
    Jul 29 03:19:53 localhost kernel: lowmem_reserve[]: 0 0 880 2023
    Jul 29 03:19:53 localhost kernel: DMA32 free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
    Jul 29 03:19:53 localhost kernel: Normal free:40324kB min:3756kB low:4692kB high:5632kB active:167076kB inactive:577492kB present:901120kB pages_scanned:60988 all_unreclaimable? no
    Jul 29 03:19:53 localhost kernel: lowmem_reserve[]: 0 0 0 9144
    Jul 29 03:19:53 localhost kernel: HighMem free:472kB min:512kB low:1732kB high:2952kB active:774704kB inactive:373484kB present:1170432kB pages_scanned:91194 all_unreclaimable? no
    Jul 29 03:19:53 localhost kernel: lowmem_reserve[]: 0 0 0 0
    Jul 29 03:19:53 localhost kernel: DMA: 0*4kB 0*8kB 0*16kB 1*32kB 1*64kB 1*128kB 1*256kB 1*512kB 1*1024kB 1*2048kB 1*4096kB = 8160kB
    Jul 29 03:19:53 localhost kernel: DMA32: empty
    Jul 29 03:19:53 localhost kernel: Normal: 27*4kB 7*8kB 2*16kB 0*32kB 1*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 1*2048kB 9*4096kB = 40324kB
    Jul 29 03:19:53 localhost kernel: HighMem: 16*4kB 1*8kB 1*16kB 0*32kB 0*64kB 1*128kB 1*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 472kB
    Jul 29 03:19:53 localhost kernel: Swap cache: add 634226, delete 634092, find 264265/280231, race 0+13
    Jul 29 03:19:53 localhost kernel: Free swap = 0kB
    Jul 29 03:19:53 localhost kernel: Total swap = 1951888kB
    Jul 29 03:19:53 localhost kernel: Free swap: 0kB
    Jul 29 03:19:53 localhost kernel: 521984 pages of RAM
    Jul 29 03:19:53 localhost kernel: 292608 pages of HIGHMEM
    Jul 29 03:19:53 localhost kernel: 5273 reserved pages
    Jul 29 03:19:53 localhost kernel: 89546 pages shared
    Jul 29 03:19:53 localhost kernel: 134 pages swap cached
    Jul 29 03:19:53 localhost kernel: 0 pages dirty
    Jul 29 03:19:53 localhost kernel: 0 pages writeback
    Jul 29 03:19:53 localhost kernel: 237 pages mapped
    Jul 29 03:19:53 localhost kernel: 4259 pages slab
    Jul 29 03:19:53 localhost kernel: 2590 pages pagetables
    Jul 29 03:19:53 localhost kernel: Out of Memory: Kill process 4177 (apache2) score 27121 and children.
    Jul 29 03:19:53 localhost kernel: Out of memory: Killed process 8511 (apache2).
    Isso apareceu nos logs após um travamento temporário de todos os servidores...o mais interessante é que após esse travamento, hoje pela manhã quando tentei acessar o servidor novamente ele tava todo normal....
    Alguma idéia????
    Agradeço a todos!
    Roberto
    Você está rodando o Apache a muito tempo nesse servidor ???
    Esse é um erro constante ???
    Aparentemente o Apache não está bem configurado e está estourando a memória, ou então está com pouca memória para trabalhar...
    Citação Postado originalmente por Marcio68Almeida Ver Post
    Oi Marcio...blz...
    é mais ou menos a seguinte situação: esse é um servidor novo...instalei ele segunda feira passada...tá radando o apache2. É possível que ele esteja estourando a memória...mas pode me dar alguma ajuda pra não acontecer isso???
    Creio que pouca memória não é...a máquina é um Intel Core 2 Duo, 2Gb Mem., e a swap foi criada com 2Gb tb...que tu acha?
    Bom, memória tem e bastante...
    Estes erros
    Código :
    demonstram que há MUITA informação cacheada e 0 de swap free.
    não lembro bem dos parâmetros, mas ache os que limitam tempo e número de páginas a cachear, por que é bem possível que tem pipa ai...
    Pessoal, cá estou eu novamente!!! Achei que o problema estaria resolvido depois que coloquei algumas regras de limites de uso de memória e cpu no apache2, mas voltou a dar o problema....agora com uma coisa interessante...
    além de parar somente o apache parou o mysql tb, depois, mais tarde, sem explicação o apache voltou mas o mysql não! segue abaixo o log kern.log...
    Por favor...preciso de alguma ajuda URGENTE!!!!
    Código :
    ############################ KERN.LOG ############################
    não consegui postar o código por ser grande demais...envio por e-mail ou msn pra quem puder ajudar....
    Grato,
    Roberto
    Última edição por askaskey; 08-08-2007 às 08:25.
