    Angry Maildrop com suporte a mysql x Erro no envio do email
    Pessoal, boa tarde!
    Estou com o seguinte problema:
    Não estou conseguindo utilizar o smtp para envio de email, configurei uma conta no Microsoft Outlook, porém dá o erro abaixo (no log do mail.log); ele não consegue entregar o email no mailbox para o usuário:
    Jul 31 16:57:38 DebianLXTeste02 postfix/smtpd[8876]: connect from srvmsc02.col[172.16.65.3]
    Jul 31 16:57:38 DebianLXTeste02 postfix/smtpd[8876]: 92805422AE: client=srvmsc02.col[172.16.65.3]
    Jul 31 16:57:38 DebianLXTeste02 postfix/cleanup[8879]: 92805422AE: message-id=<[email protected]>
    Jul 31 16:57:38 DebianLXTeste02 postfix/qmgr[8721]: 92805422AE: from=<[email protected]>, size=4668, nrcpt=1 (queue active)
    Jul 31 16:57:38 DebianLXTeste02 postfix/pipe[8880]: 92805422AE: to=<[email protected]>, relay=maildrop, delay=0.23, delays=0.1/0.05/0/0.08, dsn=5.1.1, status=bounced (user unknown. Command output: ERR: authdaemon: s_connect() failed: Permission denied Invalid user specified. )
    Jul 31 16:57:38 DebianLXTeste02 postfix/cleanup[8879]: BAB5B422B0: message-id=<[email protected]>
    Jul 31 16:57:38 DebianLXTeste02 postfix/bounce[8882]: 92805422AE: sender non-delivery notification: BAB5B422B0
    Jul 31 16:57:38 DebianLXTeste02 postfix/qmgr[8721]: 92805422AE: removed
    Jul 31 16:57:38 DebianLXTeste02 postfix/qmgr[8721]: BAB5B422B0: from=<>, size=6526, nrcpt=1 (queue active)
    Jul 31 16:57:38 DebianLXTeste02 postfix/pipe[8880]: BAB5B422B0: to=<[email protected]>, relay=maildrop, delay=0.05, delays=0.02/0/0/0.02, dsn=5.1.1, status=bounced (user unknown. Command output: ERR: authdaemon: s_connect() failed: Permission denied Invalid user specified. )
    Jul 31 16:57:38 DebianLXTeste02 postfix/qmgr[8721]: BAB5B422B0: removed
    Jul 31 16:57:41 DebianLXTeste02 postfix/smtpd[8876]: disconnect from srvmsc02.col[172.16.65.3]
    Informações adicionais:
    --Quando envio email através do console (para um dominio fictício em testes), ele entrega o emailcorretamente:
    debian:/var/spool/correio/rmoraes.com/rmoraes/Maildir/new# cat /var/www/phpinfo.php |maildrop -d [email protected]
    Eu consigo baixar através do cliente de pop3 as mensagens que eu envio localmente.
    --O log do envio no mysql:
    debian:/# tail -f /var/log/mysql/mysql.log
    100731 17:00:25 194 Connect [email protected] on
    194 Init DB postfix
    194 Query SELECT username, password, "", uid, gid, home, maildir, quota, name, "" FROM mailbox WHERE username = "[email protected]" AND (active=1)
    --Abaixo eu verifiquei que ela caiu no local correto:
    debian:/var/spool/correio/rmoraes.com/rmoraes/Maildir/new# ls
    1280605155.M683729P8856V0000000000000306I00042297_0.debian.local.int,S=29
    -- O serviço de pop3 está funcionando corretamente, ele conecta e desconecta no servidor normalmente (segue log abaixo):
    /var/log/mail.log
    Jul 31 17:10:20 DebianLXTeste02 courierpop3login: Connection, ip=[::ffff:172.16.65.3]
    Jul 31 17:10:20 DebianLXTeste02 courierpop3login: LOGIN, [email protected], ip=[::ffff:172.16.65.3]
    Jul 31 17:10:20 DebianLXTeste02 courierpop3login: LOGOUT, [email protected], ip=[::ffff:172.16.65.3], top=0, retr=0, rcvd=12, sent=39, time=0
    --Estou utilizando postfix + Mysql (com 01 domínio virtual criado) + Maildrop + Courier-imap + Courier-pop.
    -- Segue o conf do /etc/postfix (e arquivos relacionados):
    /etc/postfix/main.cf
    # See /usr/share/postfix/main.cf.dist for a commented, more complete version
    smtpd_banner = $myhostname ESMTP FATEC
    biff = no
    # appending .domain is the MUA's job.
    append_dot_mydomain = no
    # Uncomment the next line to generate "delayed mail" warnings
    #delay_warning_time = 4h
    myhostname=debian.local.int
    alias_maps=hash:/etc/aliases
    alias_database=hash:/etc/aliases
    myorigin=$mydomain
    mydestination = $mydomain, $transport_maps
    relayhost = localhost
    mynetworks = 127.0.0.0/8 172.16.0.0/16
    # mailbox_command = procmail -a "$EXTENSION"
    mailbox_size_limit = 0
    recipient_delimiter = +
    inet_interfaces = all
    #CONFIGURACOES
    queue_directory = /var/spool/postfix/
    program_directory=/usr/sbin
    command_directory = /usr/sbin
    daemon_directory = /usr/lib/postfix
    mail_owner = postfix
    default_privs=nobody
    default_transport=smtp
    readme_directory = no
    sample_directory = /etc/postfix
    sendmail_path = /usr/sbin/sendmail
    setgid_group = postdrop
    manpage_directory = /usr/local/man
    newaliases_path = /usr/bin/newaliases
    mailq_path = /usr/bin/mailq
    disable_vrfy_command=yes
    home_mailbox=Maildir/
    #Nome do dominio
    mydomain=fatec.int
    #MYSQL
    virtual_alias_maps = mysql:/etc/postfix/mysql_virtual_alias_maps.cf
    virtual_mailbox_base = /postfix
    virtual_mailbox_maps = mysql:/etc/postfix/mysql_virtual_mailbox_maps.cf
    virtual_uid_maps = static:120
    virtual_gid_maps = static:120
    transport_maps = mysql:/etc/postfix/mysql_transport_maps.cf
    #Quota
    virtual_mailbox_limit_inbox = no
    virtual_mailbox_limit_maps = mysql:/etc/postfix/mysql_virtual_mailbox_limit_maps.cf
    virtual_mailbox_limit_override = yes
    virtual_maildir_extended = yes
    virtual_create_maildirsize = yes
    virtual_mailbox_limit = 100000000
    virtual_maildir_limit_message = Desculpe, o diretorio de correio do usuario estourou sua quota, por favor tente novamente depois.
    virtual_overquota_bounce = yes
    #SASL
    #smtpd_sasl_auth_enable = yes
    #smtpd_sasl_security_options = noanonymous
    #broken_sal_auth_clients = yes
    #smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, check_relay_domains
    #MAILDROP
    fallback_transport = /usr/bin/maildrop
    maildrop_destination_recipient_limit = 1
    unknown_local_recipient_reject_code = 450
    #Finish
    #Para amavis
    #content_filter = smtp-amavis:[127.0.0.1]:10024
    /etc/postfix/master.cf
    smtp inet n - n - - smtpd
    #submission inet n - n - - smtpd
    # -o smtpd_etrn_restrictions=reject
    #628 inet n - n - - qmqpd
    pickup fifo n - n 60 1 pickup
    cleanup unix n - n - 0 cleanup
    qmgr fifo n - n 300 1 qmgr
    #qmgr fifo n - n 300 1 oqmgr
    rewrite unix - - n - - trivial-rewrite
    bounce unix - - n - 0 bounce
    defer unix - - n - 0 bounce
    trace unix - - n - 0 bounce
    verify unix - - n - 1 verify
    flush unix n - n 1000? 0 flush
    proxymap unix - - n - - proxymap
    smtp unix - - n - - smtp
    relay unix - - n - - smtp
    # -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
    showq unix n - n - - showq
    error unix - - n - - error
    local unix - n n - - local
    virtual unix - n n - - virtual
    lmtp unix - - n - - lmtp
    anvil unix - - n - 1 anvil
    maildrop unix - n n - - pipe
    flags=DRhu user=maildrop argv=/usr/bin/maildrop -w 90 -d ${recipient}
    uucp unix - n n - - pipe
    flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
    ifmail unix - n n - - pipe
    flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
    bsmtp unix - n n - - pipe
    flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -d -t$nexthop -f$sender $recipient
    scalemail-backend unix - n n - 2 pipe
    flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
    # only used by postfix-tls
    #tlsmgr fifo - - n 300 1 tlsmgr
    #smtps inet n - n - - smtpd -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes
    #587 inet n - n - - smtpd -o smtpd_enforce_tls=yes -o smtpd_sasl_auth_enable=yes
    /etc/ postfix/mysql_virtual_alias_maps.cf
    user = postfix
    password = alface
    dbname = postfix
    table = alias
    select_field = goto
    where_field = address
    hosts = localhost
    user = postfix
    password = alface
    dbname = postfix
    table = mailbox
    select_field = maildir
    where_field = username
    hosts = localhost
    user = postfix
    password = alface
    dbname = postfix
    table = domain
    select_field = transport
    where_field = domain
    hosts = localhost
    user = postfix
    password = alface
    dbname = postfix
    table = mailbox
    select_field = quota
    hosts = localhost
    Dúvidas:
    - Alguém já passou por este problema?
    - Quando o email é enviado localmente ele não loga no /var/log/mail.log, isto está correto?
    - Alguém nesta lista tá usando postfix + mysql+ maildrop?
    - Se o maildrop está conseguindo enviar os emails localmente significa que ele já está integrado com o myslq, certo?
    Agradeço as dicas de todos
    Vc tem o sasl instalado?
    Se sim , configure o Outlook para envio de mensagem por smtp autenticado.
    Se não e estiver tentando enviar essa mensagem de dentro de rede local, no main.cf altere a linha:
    "relayhost = localhost" para "relayhost = localhost, 111.111.111.111/11".
    depois /etc/init.d/postfix reload e faça testes...
