    Padrão AtualizaÇÃo Da Ios Do Cisco 1721
    E ai galera blz...
    Presiso atualizar a ios do meu rotiador seque abaixo as versões!!
    Cisco Internetwork Operating System Software
    IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(11)T8, RELEASE SOFTWARE (fc1)
    TAC Support: Cisco – Shortcut to Technical Support
    Copyright (c) 1986-2003 by cisco Systems, Inc.
    Compiled Sat 29-Mar-03 16:10 by hqluong
    Image text-base: 0x80008124, data-base: 0x807E4FE4
    ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
    turbospeed uptime is 4 days, 18 hours, 32 minutes
    System returned to ROM by power-on
    System image file is "flash:c1700-y-mz.122-11.T8.bin"
    cisco 1721 (MPC860P) processor (revision 0x100) with 29492K/3276K bytes of memory.
    Processor board ID FOC07210NXV (2554897994), with hardware revision 0000
    MPC860P processor: part number 5, mask 2
    Bridging software.
    X.25 software, Version 3.0.0.
    1 FastEthernet/IEEE 802.3 interface(s)
    2 Serial(sync/async) network interface(s)
    32K bytes of non-volatile configuration memory.
    16384K bytes of processor board System flash (Read/Write)
    Configuration register is 0x2102
    Presiso Atualizar Esta ios pra rodar o ip cef
    Alguem tem uma dica de como faço isso com segurança !!
    Desde Ja Agradeço
    Padrão Google...
    vai no google...tem bastante tutorial...vc ja tem o IOS?
    o mais dificil eh achar o IOS !!
    mas acho que o 12.2 tem CEF sim.. pois eu fazia balanceamento usando CEF no meu.. nao lembro a versao..
    mas o meu router atual usa 12.2 e faz cef ..tenho um 3660
    Padrão Contato...
    Entra em contato...tenho várias IOS...
