- Firewall
Firewall
Ola amigos;
to tendo momentos de lentidão na minha rede, tem horas q o ap chega a travar (quando olho no log tem la "critical router was rebooted"), o pessoal da suspeitando das minhas regras de firewall, abaixo tem todas as regras q tem em filter rules no meu servidor. quem puder ajudar eu agradeço:
0 chain=forward in-interface=Entrada src-address=XXX.XXX.XXX.XXX/29
action=accept
1 chain=forward in-interface=Saida src-address=192.168.1.0/24 action=accep>
2 chain=forward in-interface=Entrada src-address=CCC.CCC.CCC.CCC/25
action=accept
3 chain=forward in-interface=Entrada src-address=CCC.CCC.CCC/29
action=accept
4 X chain=forward action=drop
5 chain=forward protocol=tcp dst-port=135 action=drop
6 ;;; Allow Established connections
chain=input connection-state=established action=accept
7 ;;; Allow UDP
chain=input protocol=udp action=accept
8 X chain=input protocol=tcp dst-port=23 action=drop
9 ;;; Allow ICMP
chain=input protocol=icmp action=accept
10 ;;; Allow access to router from known network
chain=input src-address=192.168.0.0/24 action=accept
11 ;;; drop invalid connections
chain=forward protocol=tcp connection-state=invalid action=drop
12 ;;; allow already established connections
chain=forward connection-state=established action=accept
13 ;;; allow related connections
chain=forward connection-state=related action=accept
14 chain=forward src-address=0.0.0.0/8 action=drop
15 chain=forward dst-address=0.0.0.0/8 action=drop
16 chain=forward src-address=127.0.0.0/8 action=drop
17 chain=forward dst-address=127.0.0.0/8 action=drop
18 chain=forward src-address=224.0.0.0/3 action=drop
19 chain=forward dst-address=224.0.0.0/3 action=drop
20 chain=forward protocol=tcp action=jump jump-target=tcp
21 chain=forward protocol=udp action=jump jump-target=udp
22 chain=forward protocol=icmp action=jump jump-target=icmp
23 ;;; deny TFTP
chain=tcp protocol=tcp dst-port=69 action=drop
24 ;;; deny RPC portmapper
chain=tcp protocol=tcp dst-port=111 action=drop
25 ;;; deny RPC portmapper
chain=tcp protocol=tcp dst-port=135 action=drop
26 ;;; deny NBT
chain=tcp protocol=tcp dst-port=137-139 action=drop
27 ;;; deny cifs
chain=tcp protocol=tcp dst-port=445 action=drop
28 ;;; deny NFS
chain=tcp protocol=tcp dst-port=2049 action=drop
29 ;;; deny NetBus
chain=tcp protocol=tcp dst-port=12345-12346 action=drop
30 ;;; deny NetBus
chain=tcp protocol=tcp dst-port=20034 action=drop
31 ;;; deny BackOriffice
chain=tcp protocol=tcp dst-port=3133 action=drop
32 ;;; deny DHCP
chain=tcp protocol=tcp dst-port=67-68 action=drop
33 ;;; deny TFTP
chain=udp protocol=udp dst-port=69 action=drop
34 ;;; deny PRC portmapper
chain=udp protocol=udp dst-port=111 action=drop
35 ;;; deny PRC portmapper
chain=udp protocol=udp dst-port=135 action=drop
36 ;;; deny NBT
chain=udp protocol=udp dst-port=137-139 action=drop
37 ;;; deny NFS
chain=udp protocol=udp dst-port=2049 action=drop
38 ;;; deny BackOriffice
chain=udp protocol=udp dst-port=3133 action=drop
39 ;;; drop invalid connections
chain=icmp protocol=icmp icmp-options=0:0 action=accept
40 ;;; allow established connections
chain=icmp protocol=icmp icmp-options=3:0 action=accept
41 ;;; allow already established connections
chain=icmp protocol=icmp icmp-options=3:1 action=accept
42 ;;; allow source quench
chain=icmp protocol=icmp icmp-options=4:0 action=accept
43 ;;; allow echo request
chain=icmp protocol=icmp icmp-options=8:0 action=accept
44 ;;; allow time exceed
chain=icmp protocol=icmp icmp-options=11:0 action=accept
45 ;;; allow parameter bad
chain=icmp protocol=icmp icmp-options=12:0 action=accept
46 ;;; deny all other types
chain=icmp action=drop
47 ;;; Bloqueio acesso entre usuarios
chain=forward src-address=192.168.1.0/24 dst-address=192.168.1.0/24
action=drop
48 chain=forward protocol=tcp dst-port=135-139 action=drop action=accept
49 chain=forward protocol=udp dst-port=135-139 action=drop action=accept
50 chain=forward protocol=tcp dst-port=445-449 action=drop action=accept
51 chain=forward protocol=udp dst-port=445-449 action=drop action=accept
52 ;;; Allow access to router from known network 2
chain=input src-address=192.168.1.0/24 action=accept
53 ;;; Bloqueio acesso entre usuarios 2
action=drop
54 ;;; Sanity Check
chain=forward action=jump jump-target=sanity-check
55 ;;; Deny illegal NAT traversal
chain=sanity-check packet-mark=nat-traversal action=jump
jump-target=drop
56 ;;; Block port scans
chain=sanity-check protocol=tcp psd=20,3s,3,1
action=add-src-to-address-list address-list=blocked-addr
address-list-timeout=1d
57 ;;; Block TCP Null scan
chain=sanity-check protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
58 ;;; Block TCP Xmas scan
chain=sanity-check protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
59 chain=sanity-check protocol=tcp src-address-list=blocked-addr action=jum>
jump-target=drop
....to be continued.....
Última edição por Mundo_digital; 03-08-2007 às 18:47.
continuação...
continuação...
60 ;;; Drop TCP RST
chain=sanity-check protocol=tcp tcp-flags=rst action=jump
jump-target=drop
61 ;;; Drop TCP SYN+FIN
chain=sanity-check protocol=tcp tcp-flags=fin,syn action=jump
jump-target=drop
62 ;;; Dropping invalid connections at once
chain=sanity-check connection-state=invalid action=jump
jump-target=drop
63 ;;; Accepting already established connections
chain=sanity-check connection-state=established action=accept
64 ;;; Also accepting related connections
chain=sanity-check connection-state=related action=accept
65 ;;; Drop all traffic that goes to multicast or broadcast addresses
chain=sanity-check dst-address-type=broadcast,multicast action=jump
jump-target=drop
66 ;;; Drop all traffic that goes from multicast or broadcast addresses
chain=sanity-check src-address-type=broadcast,multicast action=jump
jump-target=drop
67 chain=forward protocol=tcp action=jump jump-target=restrict-tcp
68 chain=forward protocol=udp action=jump jump-target=restrict-udp
69 chain=forward action=jump jump-target=restrict-ip
70 chain=restrict-tcp connection-mark=auth action=reject
reject-with=icmp-network-unreachable
71 ;;; anti-spam policy
chain=restrict-tcp connection-mark=smtp action=jump
jump-target=smtp-first-drop
72 chain=smtp-first-drop src-address-list=first-smtp
action=add-src-to-address-list address-list=approved-smtp
address-list-timeout=0s
73 chain=smtp-first-drop src-address-list=approved-smtp action=return
74 chain=smtp-first-drop action=add-src-to-address-list
address-list=first-smtp address-list-timeout=0s
75 chain=smtp-first-drop action=reject reject-with=icmp-network-unreachable
76 chain=restrict-tcp connection-mark=other-tcp action=jump jump-target=dro>
77 chain=restrict-udp connection-mark=other-udp action=jump jump-target=dro>
78 chain=restrict-ip connection-mark=other action=jump jump-target=drop
79 ;;; Allow local traffic (between router applications)
chain=input src-address-type=local dst-address-type=local action=accept
80 ;;; Sanity Check
chain=input action=jump jump-target=sanity-check
81 ;;; Dropping packets not destined to the router itself, including all br>
cast traffic
chain=input dst-address-type=!local action=jump jump-target=drop
82 ;;; Allow pings, but at a very limited rate (5 per sec)
chain=input connection-mark=ping limit=5,5 action=accept
83 chain=input action=jump jump-target=drop
84 chain=dhcp src-address=0.0.0.0 dst-address=255.255.255.255 action=accept
85 chain=dhcp src-address=0.0.0.0 dst-address-type=local action=accept
86 chain=dhcp dst-address-type=local src-address-list=local-addr
action=accept
87 ;;; SSH (22/TCP)
chain=local-services connection-mark=ssh action=accept
88 ;;; DNS
chain=local-services connection-mark=dns action=accept
89 ;;; HTTP Proxy (3128/TCP)
chain=local-services connection-mark=proxy action=accept
90 ;;; Winbox (8291/TCP)
chain=local-services connection-mark=winbox action=accept
91 ;;; Drop Other Local Services
chain=local-services action=drop
92 ;;; SSH (22/TCP)
chain=public-services connection-mark=ssh action=accept
93 ;;; PPTP (1723/TCP)
chain=public-services connection-mark=pptp action=accept
94 ;;; GRE for PPTP
chain=public-services connection-mark=gre action=accept
95 ;;; Drop Other Public Services
chain=public-services action=drop
96 ;;; Drop Blaster Worm
chain=virus protocol=tcp dst-port=135-139 action=drop
97 ;;; Drop Messenger Worm
chain=virus protocol=udp dst-port=135-139 action=drop
98 ;;; Drop Blaster Worm
chain=virus protocol=tcp dst-port=445 action=drop
99 ;;; Drop Blaster Worm
chain=virus protocol=udp dst-port=445 action=drop
100 ;;; ________
chain=virus protocol=tcp dst-port=593 action=drop
101 ;;; ________
chain=virus protocol=tcp dst-port=1024-1030 action=drop
102 ;;; Drop MyDoom
chain=virus protocol=tcp dst-port=1080 action=drop
103 ;;; ________
chain=virus protocol=tcp dst-port=1214 action=drop
104 ;;; ndm requester
chain=virus protocol=tcp dst-port=1363 action=drop
105 ;;; ndm server
chain=virus protocol=tcp dst-port=1364 action=drop
106 ;;; screen cast
chain=virus protocol=tcp dst-port=1368 action=drop
107 ;;; hromgrafx
chain=virus protocol=tcp dst-port=1373 action=drop
108 ;;; cichlid
chain=virus protocol=tcp dst-port=1377 action=drop
109 ;;; Worm
chain=virus protocol=tcp dst-port=1433-1434 action=drop
110 ;;; Bagle Virus
chain=virus protocol=tcp dst-port=2745 action=drop
111 ;;; Drop Dumaru.Y
chain=virus protocol=tcp dst-port=2283 action=drop
112 ;;; Drop Beagle
chain=virus protocol=tcp dst-port=2535 action=drop
113 ;;; Drop Beagle.C-K
114 ;;; Drop MyDoom
chain=virus protocol=tcp dst-port=3127-3128 action=drop
115 ;;; Drop Backdoor OptixPro
chain=virus protocol=tcp dst-port=3410 action=drop
116 ;;; Worm
chain=virus protocol=tcp dst-port=4444 action=drop
117 ;;; Worm
chain=virus protocol=udp dst-port=4444 action=drop
118 ;;; Drop Sasser
chain=virus protocol=tcp dst-port=5554 action=drop
119 ;;; Drop Beagle.B
chain=virus protocol=tcp dst-port=8866 action=drop
120 ;;; Drop Dabber.A-B
chain=virus protocol=tcp dst-port=9898 action=drop
121 ;;; Drop Dumaru.Y
chain=virus protocol=tcp dst-port=10000 action=drop
122 ;;; Drop MyDoom.B
chain=virus protocol=tcp dst-port=10080 action=drop
123 ;;; Drop NetBus
chain=virus protocol=tcp dst-port=12345 action=drop
124 ;;; Drop Kuang2
chain=virus protocol=tcp dst-port=17300 action=drop
125 ;;; Drop SubSeven
chain=virus protocol=tcp dst-port=27374 action=drop
126 ;;; Drop PhatBot, Agobot, Gaobot
chain=virus protocol=tcp dst-port=65506 action=drop
127 X ;;; jump to the virus chain
chain=forward action=jump jump-target=virus
128 ;;; allow established connections
129 ;;; allow related connections
130 ;;; drop invalid connections
chain=forward connection-state=invalid action=drop
131 ;;; allow ping
chain=forward protocol=icmp action=accept
132 ;;; allow udp
chain=forward protocol=udp action=accept
133 chain=input protocol=tcp psd=21,3s,3,1 action=add-src-to-address-list
address-list=port scanners address-list-timeout=0s
134 X ;;; drop everything else
135 chain=input protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
action=accept
136 chain=input protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
action=accept
137 X ;;; limitar conexoes simultaneas
chain=forward src-address=192.168.1.10 protocol=tcp tcp-flags=syn
connection-limit=30,32 action=drop
138 ;;; CONTROLE CONEXOES SIMULTANEAS
chain=forward src-address=192.168.1.37 protocol=tcp dst-port=1024-65535
tcp-flags=syn connection-limit=10,32 action=drop
pronto, vale lembrar que apesar de ter regra pra clientes nao se enchergarem, e a opcao ta marcada no cartao, os clientes continuam se enchergando
Aguardo a ajuda de vcs com ansiedade.
Amigo, analisando o seu problema, vc criou duas regras para a mesma coisa emuito mais trabalhoso, me procure que passo um conjunto de regras simples e extremamente eficiente.
boa tarde
amigo, não será que o seu link está com cargalo, poste mais a respeito de seus link quantidade de clientes.
