  1. Olá pessoal...
    Estou tentando montar um servidor pppoe e estou tendo o seguinte problema:
    Quando conecto autentica normal, mas quando tento navegar a conexao cai...
    Andei olhando os logs e encontrei o seguinte
    Aug 31 15:39:09 barrao pppoe-server[6863]: Session 4 created for client 00:1a:4d :a1:2b:2f (172.16.0.5) on eth0 using Service-Name 'InoveNet'
    Aug 31 15:39:09 barrao pppd[6863]: Plugin rp-pppoe.so loaded.
    Aug 31 15:39:09 barrao pppd[6863]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b3
    Aug 31 15:39:09 barrao pppd[6863]: Plugin radius.so loaded.
    Aug 31 15:39:09 barrao pppd[6863]: RADIUS plugin initialized.
    Aug 31 15:39:09 barrao pppd[6863]: Plugin radattr.so loaded.
    Aug 31 15:39:09 barrao pppd[6863]: RADATTR plugin initialized.
    Aug 31 15:39:09 barrao pppd[6863]: pppd 2.4.2b3 started by root, uid 0
    Aug 31 15:39:09 barrao pppd[6863]: Using interface ppp0
    Aug 31 15:39:09 barrao pppd[6863]: Connect: ppp0 <--> /dev/pts/3
    Aug 31 15:39:11 barrao pppd[6863]: PAP peer authentication succeeded for marcelo
    Aug 31 15:39:11 barrao pppd[6863]: not replacing existing default route to eth1 [192.168.100.1]
    Aug 31 15:39:11 barrao pppd[6863]: local IP address 172.16.0.1
    Aug 31 15:39:11 barrao pppd[6863]: remote IP address 172.16.0.10
    Aug 31 15:39:14 barrao pppoe[30253]: Packet too big! Check MTU on PPP interface
    Aug 31 15:39:25 barrao pppoe[6864]: send (sendPacket): No buffer space available
    Aug 31 15:39:56 barrao last message repeated 22 times
    Aug 31 15:40:00 barrao last message repeated 14 times
    Aug 31 15:40:01 barrao /USR/SBIN/CRON[6879]: (root) CMD ([ -d /etc/shaper ] && / etc/init.d/shaper timecheck)
    Aug 31 15:40:05 barrao pppoe[6864]: send (sendPacket): No buffer space available
    Aug 31 15:40:35 barrao last message repeated 39 times
    Aug 31 15:40:40 barrao pppoe[30253]: Packet too big! Check MTU on PPP interface
    Aug 31 15:40:40 barrao pppoe[6864]: send (sendPacket): No buffer space available
    Aug 31 15:40:40 barrao last message repeated 3 times
    Aug 31 15:40:41 barrao pppd[6863]: No response to 2 echo-requests
    Aug 31 15:40:41 barrao pppd[6863]: Serial link appears to be disconnected.
    Aug 31 15:40:45 barrao pppd[6863]: Connection terminated.
    Aug 31 15:40:45 barrao pppd[6863]: Connect time 1.6 minutes.
    Aug 31 15:40:45 barrao pppd[6863]: Sent 151591 bytes, received 126698 bytes.
    Aug 31 15:40:45 barrao pppoe[6864]: read (asyncReadFromPPP): Session 4: Input/ou tput error
    Aug 31 15:40:45 barrao pppd[6863]: Exit.
    Aug 31 15:40:45 barrao pppoe-server[5942]: Session 4 closed for client 00:1a:4d: a1:2b:2f (172.16.0.5) on eth0
    Aug 31 15:40:45 barrao pppoe-server[5942]: Sent PADT
    Acredito q seja o MTU... como posso alterar o valor dele....
    ele esta atualmente como 1480
    ppp0 Encapsulamento do Link: Protocolo Ponto-a-Ponto
    inet end.: 172.16.0.1 P-a-P:172.16.0.10 Masc:255.255.255.255
    UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1480 Métrica:1
    RX packets:17 errors:0 dropped:0 overruns:0 frame:0
    TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
    colisões:0 txqueuelen:3
    RX bytes:7311 (7.1 KiB) TX bytes:6718 (6.5 KiB)
  2. amigo posta suas conf ae pra mim analisar
  3. # PPP options for the PPPoE server
    # LIC: GPL
    require-pap
    login
    lcp-echo-interval 10
    lcp-echo-failure 3
    ms-dns 200.254.210.132
    ms-dns 200.223.142.82
    netmask 255.255.255.0
    mtu 1488
    defaultroute
    noipdefault
    usepeerdns
    plugin radius.so
    plugin radattr.so
    a conexao com o radius esta beleza... o pppoe esta consultando o radius q esta consultando o mysql...
    agora o problema eh q a conexao nao segura
    ela conecta e cai.
    da o erro No response to 2 echo-requests
  4. tente deixar somente assim
    require-pap
    login
    lcp-echo-failure 5
    plugin radius.so
    plugin radattr.so
    Citação Postado originalmente por fr4jol4 Ver Post
    # LIC: GPL
    require-pap
    login
    lcp-echo-failure 3
    mtu 1488
    defaultroute
    noipdefault
    usepeerdns
    plugin radius.so
    plugin radattr.so
    ela conecta e cai.
  5. Ok. coloquei assim o arquivo mas continua com o mesmo erro!!
    Sep 3 15:28:00 barrao pppd[24252]: Plugin radius.so loaded.
    Sep 3 15:28:00 barrao pppd[24252]: RADIUS plugin initialized.
    Sep 3 15:28:00 barrao pppd[24252]: Plugin radattr.so loaded.
    Sep 3 15:28:00 barrao pppd[24252]: RADATTR plugin initialized.
    Sep 3 15:28:00 barrao pppd[24252]: pppd 2.4.2b3 started by root, uid 0
    Sep 3 15:28:00 barrao pppd[24252]: Using interface ppp0
    Sep 3 15:28:00 barrao pppd[24252]: Connect: ppp0 <--> /dev/pts/1
    Sep 3 15:28:02 barrao pppd[24252]: PAP peer authentication succeeded for marcelo
    Sep 3 15:28:02 barrao pppd[24252]: local IP address 172.16.0.1
    Sep 3 15:28:02 barrao pppd[24252]: remote IP address 172.16.0.10
    Sep 3 15:29:11 barrao pppd[24252]: No response to 3 echo-requests
    Sep 3 15:29:11 barrao pppd[24252]: Serial link appears to be disconnected.
    Sep 3 15:29:18 barrao pppd[24252]: Connection terminated.
    Sep 3 15:29:18 barrao pppd[24252]: Connect time 1.2 minutes.
    Sep 3 15:29:18 barrao pppd[24252]: Sent 77289 bytes, received 14957 bytes.
    Sep 3 15:29:18 barrao pppoe[24253]: read (asyncReadFromPPP): Session 1: Input/output error
    Sep 3 15:29:18 barrao pppd[24252]: Exit.
    Sep 3 15:29:18 barrao pppoe-server[24251]: Session 1 closed for client 00:1a:4d:a1:2b:2f (172.16.0.2) on eth0
    Sep 3 15:29:18 barrao pppoe-server[24251]: Sent PADT
  1. Respostas: 8
    Último Post: 17-07-2006, 12:26
  2. problemas com pppoe + radius + bandlimit
    Por cooperbr no fórum Redes
    Respostas: 13
    Último Post: 30-08-2005, 14:29
  3. Problemas com instalação de PPPoE
    Por sarna no fórum Servidores de Rede
    Último Post: 07-05-2005, 14:21
  4. Problemas com PPPoE + radiusd
    Por Ney Corrêa no fórum Redes
    Último Post: 01-10-2004, 12:47
  5. Problema com PPPoE
    Por haas no fórum Sistemas Operacionais
    Último Post: 02-08-2004, 19:01
