  1. Instalei o vsftpd porém não criou o rc.vsftpd.
    Ok, copiei o rc.httpd e alterei para o arquivo do vsftpd.
    Meus arquivos ficaram dessa forma.
    Algum auxilio ?
    # Example config file /etc/vsftpd.conf
    # The default compiled in settings are fairly paranoid. This sample file
    # loosens things up a bit, to make the ftp daemon more usable.
    # Please see vsftpd.conf.5 for all compiled in defaults.
    # READ THIS: This example file is NOT an exhaustive list of vsftpd options.
    # Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
    # capabilities.
    # Run standalone? vsftpd can run either from an inetd or as a standalone
    # daemon started from an initscript.
    listen=YES
    # Allow anonymous FTP? (Beware - allowed by default if you comment this out).
    anonymous_enable=NO
    # Uncomment this to allow local users to log in.
    local_enable=YES
    # Uncomment this to enable any form of FTP write command.
    write_enable=YES
    # Default umask for local users is 077. You may wish to change this to 022,
    # if your users expect that (022 is used by most other ftpd's)
    local_umask=022
    # Uncomment this to allow the anonymous FTP user to upload files. This only
    # has an effect if the above global write enable is activated. Also, you will
    # obviously need to create a directory writable by the FTP user.
    #anon_upload_enable=YES
    # Uncomment this if you want the anonymous FTP user to be able to create
    # new directories.
    #anon_mkdir_write_enable=YES
    # Activate directory messages - messages given to remote users when they
    # go into a certain directory.
    dirmessage_enable=YES
    # Activate logging of uploads/downloads.
    xferlog_enable=YES
    # Make sure PORT transfer connections originate from port 20 (ftp-data).
    connect_from_port_20=YES
    # If you want, you can arrange for uploaded anonymous files to be owned by
    # a different user. Note! Using "root" for uploaded files is not
    # recommended!
    #chown_uploads=YES
    #chown_username=whoever
    # You may override where the log file goes if you like. The default is shown
    # below.
    xferlog_file=/var/log/vsftpd.log
    # If you want, you can have your log file in standard ftpd xferlog format
    xferlog_std_format=YES
    # You may change the default value for timing out an idle session.
    #idle_session_timeout=600
    # You may change the default value for timing out a data connection.
    #data_connection_timeout=120
    # It is recommended that you define on your system a unique user which the
    # ftp server can use as a totally isolated and unprivileged user.
    nopriv_user=ftpsecure
    # Enable this and the server will recognise asynchronous ABOR requests. Not
    # recommended for security (the code is non-trivial). Not enabling it,
    # however, may confuse older FTP clients.
    #async_abor_enable=YES
    # By default the server will pretend to allow ASCII mode but in fact ignore
    # the request. Turn on the below options to have the server actually do ASCII
    # mangling on files when in ASCII mode.
    # Beware that on some FTP servers, ASCII support allows a denial of service
    # attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd
    # predicted this attack and has always been safe, reporting the size of the
    # raw file.
    # ASCII mangling is a horrible feature of the protocol.
    ascii_upload_enable=YES
    ascii_download_enable=YES
    # You may fully customise the login banner string:
    #ftpd_banner=Welcome to blah FTP service.
    # You may specify a file of disallowed anonymous e-mail addresses. Apparently
    # useful for combatting certain DoS attacks.
    #deny_email_enable=YES
    # (default follows)
    #banned_email_file=/etc/vsftpd.banned_emails
    # You may specify an explicit list of local users to chroot() to their home
    # directory. If chroot_local_user is YES, then this list becomes a list of
    # users to NOT chroot().
    chroot_list_enable=YES
    # (default follows)
    chroot_list_file=/etc/vsftpd.chroot_list
    chroot_local_user=YES
    # You may activate the "-R" option to the builtin ls. This is disabled by
    # default to avoid remote users being able to cause excessive I/O on large
    # sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
    # the presence of the "-R" option, so there is a strong case for enabling it.
    ls_recurse_enable=YES
    # To run vsftpd in standalone mode (rather than through inetd), uncomment
    # the line below.
    listen=YES
  2. Qual o erro meu querido??? poste a mensager de erro, os logs..... seja específico...
  1. Erro ao startar o servidor dhcp
    Por belvio no fórum Servidores de Rede
    Último Post: 17-10-2005, 12:17
  2. Erro ao startar DHCP
    Por orb no fórum Servidores de Rede
    Último Post: 10-06-2005, 10:23
  3. erro ao startar httpd
    Por ernesto no fórum Servidores de Rede
    Último Post: 18-11-2004, 11:23
  4. Erro ao logar no VSFTPD 1.2.1
    Por César Menezes no fórum Servidores de Rede
    Último Post: 14-10-2004, 09:26
  5. Erro ao Startar o Squid
    Respostas: 7
    Último Post: 07-07-2003, 14:58
