    Padrão NTOP com problemas
    Senhores, alguem aqui ja configurou o ntop ?
    Não estou conseguindo rodar mais o ntop.
    Abaixo o erro.
    Ja dei permissao 777 pra testar e mesmo asim num vai.
    ntop
    Tue Sep 4 11:59:28 2007 NOTE: Interface merge enabled by default
    Tue Sep 4 11:59:28 2007 Initializing gdbm databases
    Tue Sep 4 11:59:28 2007 **ERROR** ....open of /var/ntop/prefsCache.db failed: Can't be writer
    Tue Sep 4 11:59:28 2007 Possible solution: please use '-P <directory>'
    Tue Sep 4 11:59:28 2007 **FATAL_ERROR** GDBM open failed, ntop shutting down...
    Tue Sep 4 11:59:28 2007 CLEANUP[t3086666176]: ntop caught signal 2
    Tue Sep 4 11:59:28 2007 THREADMGMT[t3086666176]: ntop RUNSTATE: SHUTDOWN(7)
    Tue Sep 4 11:59:28 2007 CLEANUP[t3086666176] catching thread is MAIN
    Tue Sep 4 11:59:28 2007 CLEANUP: Running threads
    Tue Sep 4 11:59:28 2007 CLEANUP: Locking purge mutex (may block for a little while)
    Tue Sep 4 11:59:28 2007 CLEANUP: Locked purge mutex, continuing shutdown
    Tue Sep 4 11:59:28 2007 CLEANUP: Continues
    Tue Sep 4 11:59:28 2007 PLUGIN_TERM: Unloading plugins (if any)
    Tue Sep 4 11:59:28 2007 CLEANUP: Clean up complete
    Tue Sep 4 11:59:28 2007 THREADMGMT[t3086666176]: ntop RUNSTATE: TERM(8)
    Tue Sep 4 11:59:28 2007 ===================================
    Tue Sep 4 11:59:28 2007 ntop is shutdown...
    Ele reclama do arquivo /var/ntop/prefsCache.db, esse arquivo existe? está com permissão de gravação nesse arquivo?
    Sim, está com 777 e o usuário dono da pasta /var/ntop
    # ls -ld /var/ntop
    drwxrwxrwx 3 ntop nobody 4096 Sep 4 11:31 /var/ntop
    /var/log # ls -ld /var/ntop/*
    -rwxrwxrwx 1 ntop nobody 126968 Sep 4 11:47 /var/ntop/addressQueue.db
    -rwxrwxrwx 1 ntop nobody 303685 Sep 4 11:47 /var/ntop/dnsCache.db
    -rwxrwxrwx 1 ntop nobody 237568 Sep 4 11:31 /var/ntop/fingerprint.db
    -rwxrwxrwx 1 ntop nobody 12288 Sep 4 11:31 /var/ntop/LsWatch.db
    -rwxrwxrwx 1 ntop nobody 1110238 Sep 4 11:20 /var/ntop/macPrefix.db
    -rwxrwxrwx 1 ntop nobody 5 Sep 4 11:31 /var/ntop/ntop.pid
    -rwxrwxrwx 1 ntop nobody 12546 Sep 4 11:31 /var/ntop/ntop_pw.db
    -rwxrwxrwx 1 ntop nobody 13362 Sep 4 11:39 /var/ntop/prefsCache.db
    drwxrwxrwx 5 ntop nobody 4096 Sep 4 11:31 /var/ntop/rrd
