    Padrão Servidor Desligando no mesmo horario todos os dias.
    Pessoal estou com um problema aqui, meu servidor esta desligando todos os dias no mesmo horario e fica essas msgs no Terminal... O que pode ser, Nao tem nada no agendamento e nem no scripts.
    sep/21/2007 10:36:39 system,error,critical router was rebooted without proper shutdown
    sep/21/2007 12:56:22 system,error,critical login failure for user admin from 10.0.0.88 v
    ia winbox
    sep/23/2007 15:26:48 system,error,critical router was rebooted without proper shutdown
    sep/24/2007 14:06:03 system,error,critical router was rebooted without proper shutdown
    sep/24/2007 18:44:55 system,error,critical login failure for user admin via winbox
    sep/25/2007 11:13:36 system,error,critical router was rebooted without proper shutdown
    sep/26/2007 11:46:37 system,error,critical login failure for user admin via winbox
    sep/27/2007 11:39:16 system,error,critical router was rebooted without proper shutdown
    Terminal vt102 detected, using multiline input mode
    [[email protected] MK] >
    10.0.0.88 - quem usa ess ip ae na sua rede ?
    pq a cada reboot aparece uma tentativa de acesso nao autorizado??
    ja tentou chegar se nao esta com o watchdog ativo?
