  1. BEM PESSOAL TENHO UMA PLACA LG COM CHIPSET RLT8180 COLOCO PRA CARREGADA MANUALMENTE PELO RC.LOCAL QUANDO O SISTEMA É LIGADO, EU USO O CONECTIVA, BEM ABAIXO SEGUE A CONFIGURAÇÃO DO ARQUIVO NET Q É CARREGADO JUNTO COM O DRIVER DA PLACA QUANDO O SISTEMA É INICIADO, QUERO A AJUDA DE V6 PRA COLOCAR UMA CHAVE NO SINAL, JÁ TENTEI COLOCAR SÓ QUE NÃO CONSEGUIR CONECTAR COM A INTERNET, ME AJUDEM POR FAVOR SEGUE ABAIXO O ARQUIVO NET.
    #!/bin/sh
    # Atalhos de comando
    IWPRIV=`which iwpriv`
    INSMOD=`which insmod`
    RMMOD=`which rmmod`
    IFCONFIG=`which ifconfig`
    ROUTE=`which route`
    # Carrega o driver
    $INSMOD -f rtl8180_24x.o
    # Tipo da Comunicação
    case "$1" in
    ap)
    echo "ap"
    # Config AP mode
    # Assign SSID and operation channel.
    $IWPRIV wlan0 wlan_para ssid=APMucambo
    $IWPRIV wlan0 wlan_para channel=2
    infra)
    echo "infra"
    # Config infrastructure mode
    # Assign network type and desired SSID.
    $IWPRIV wlan0 wlan_para networktype=infra
    $IWPRIV wlan0 wlan_para ssid2scan=APMucambo
    adhoc)
    echo "adhoc"
    # 'ssid' and 'channel' are the default setting
    # and meaningful if this is the first station
    # in an IBSS.
    $IWPRIV wlan0 wlan_para ssid2scan=wireless
    $IWPRIV wlan0 wlan_para networktype=adhoc
    $IWPRIV wlan0 wlan_para ssid=wireless1
    $RMMOD rtl8180_24x
    echo "Usage: $0 {ap | infra | adhoc}"
    exit 1
    esac
    # Configuração Básica
    # Alguns usam essa opção, parece funcionar
    $IWPRIV wlan0 wlan_para networktype=auto
    $IWPRIV wlan0 wlan_para basicrates=0xf
    $IWPRIV wlan0 wlan_para oprates=0xf
    $IWPRIV wlan0 wlan_para fraghres=512
    $IWPRIV wlan0 wlan_para preamble=auto
    # Ativar ou desativar debug-message
    $IWPRIV wlan0 msglevel 0
    # Config WEP mode
    #$IWPRIV wlan0 wlan_para encmode=on
    #$IWPRIV wlan0 wlan_para wepmode=on
    #$IWPRIV wlan0 wlan_para encmode=wep,wepmode=wep40
    #$IWPRIV wlan0 wlan_para wepmode=wep40,wepdkeyid=1,wepkey40_1=1234567891
    #$IWPRIV wlan0 wlan_para authtype=sharedkey
    # Enable wireless lan driver
    # É estranho, mas primeiro o povo desliga, para depois ligar :-)
    $IWPRIV wlan0 disable
    $IWPRIV wlan0 enable
    # Configure wlan0 IP address
    $IFCONFIG wlan0 192.168.1.254
    echo "$($IFCONFIG wlan0)"
    _____________________________________
    SE ALGUEM PODER ME JUDAR FICARIA MUITO GRATO.
  2. Pelo Amor De Deus Estou Precisando Muito Da Ajuda De Voces Quem Puder Me Ajudar Eu Agradeceria Muito.
  3. Descomente essas linhas (tire o # )
    Config WEP mode
    $IWPRIV wlan0 wlan_para encmode=wep,wepmode=wep40 (tipo de chave)
    $IWPRIV wlan0 wlan_para wepmode=wep40,wepdkeyid=1,wepkey40_1=(chave wep)
    pronto.
  4. Citação Postado originalmente por Pedro0278 Ver Post
    Config WEP mode
    pronto.
    Pedro amigo já descomentei as linhas e deixei todas assim:
    CONECTAVA NORMAL COLOCANDO ESSA CHAVE SÓ Q NÃO ACESSA A INTERNET DE JEITO NENHUM, SE VC PODER ANALISAR BEM ESSE ARQUINO NET PRA VER SE TEM ALGUMA COISA ERRA EU AGRADEÇERIA PQ SOU NOVO EM LINUX. ABRAÇO E FICO MUITO GRATO.
  5. Seu provedor mudou a chave?
  1. Respostas: 8
    Último Post: 18-06-2007, 11:44
  2. Repetição de Sinal Wireless
    Por clistenis no fórum Redes
    Respostas: 5
    Último Post: 11-05-2004, 19:10
  3. Colocar Texto no Arquivo??
    Por c4f0f0 no fórum Servidores de Rede
    Último Post: 05-02-2004, 08:45
  4. Novato se metendo a colocar servidor no ar!!!
    Por Scratsh no fórum Servidores de Rede
    Último Post: 13-10-2003, 12:45
  5. como colocar temas no WindowMaker
    Por Wronieri no fórum Servidores de Rede
    Último Post: 30-04-2003, 13:31
