    Padrão Nao sei mais onde procurar - Erro no Squid
    All url_rewriter processes are busy.
    Consider increasing the number of url_rewriter processes to at least 14 in your config file.
    Nao sei mais onde procurar domentação sobre essa mensagem (acima) que sempre aparece no meu cache.log e o pior e que vira e mexe aparece a mensagem que a URL nao pode ser encontrada na maioria de meus clientes...
    Alguem pode me ajudar?
    Padrão squid.conf
    # WELCOME TO SQUID 2.6.STABLE14
    http_port 192.168.0.1:8080 transparent
    hierarchy_stoplist cgi-bin ?
    cache deny QUERY
    acl apache rep_header Server ^Apache
    broken_vary_encoding allow apache
    cache_mem 32 MB
    cache_swap_low 90
    cache_swap_high 95
    maximum_object_size 4096 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 4096 KB
    cache_dir diskd /squid-cache 15000 16 256 Q1=72 Q2=64
    access_log /usr/local/squid/var/logs/access.log squid
    cache_log /usr/local/squid/var/logs/cache.log
    cache_store_log /usr/local/squid/var/logs/store.log
    refresh_pattern . 0 20% 4320
    acl blockedsites url_regex -i "/etc/squid/bloqueados/sites_proibidos.txt"
    acl unblockedsites url_regex -i "/etc/squid/bloqueados/sites_liberados.txt"
    acl proxys url_regex "/etc/squid/bloqueados/proxys.txt"
    acl spyware url_regex "/etc/squid/bloqueados/blacklistspy.txt"
    acl malware1 dstdomain "/etc/squid/bloqueados/malware1.txt"
    acl rede_interna src 192.168.0.0/24
    #Recommended minimum configuration:
    acl all src 192.168.0.0/24
    acl SSL_ports port 443
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl CONNECT method CONNECT
    acl interna url_regex -i 192.168.0
    acl limites url_regex -i ftp .exe .mp3 .vqf .tar.gz .gz .rpm .zip .rar .avi .mpeg .mpe .mpg .qt .ram .rm .iso .raw .wav
    #Default:
    # http_access deny all
    http_access deny blockedsites !unblockedsites
    http_access deny spyware malware1 proxys
    http_access allow rede_interna
    # Only allow cachemgr access from localhost
    http_access deny manager
    # Deny requests to unknown ports
    http_access deny !Safe_ports
    # Deny CONNECT to other than SSL ports
    # And finally deny all other access to this proxy
    http_reply_access allow all
    # TAG: redirect_program
    redirect_program /usr/local/squid/etc/bannerfilter/redirector.pl
    #Allow ICP queries from everyone
    icp_access allow all
    cache_effective_user nobody
    cache_effective_group nogroup
    delay_pools 2
    delay_class 1 2
    delay_parameters 1 -1/-1 -1/-1
    delay_access 1 allow interna
    delay_class 2 2
    delay_parameters 2 -1/-1 6000/6000
    delay_access 2 allow limites
    error_directory /usr/local/squid/share/errors/Portuguese
    coredump_dir /squid-cache
    Última edição por cleverup; 04-10-2007 às 09:45.
    Suponhamos que seu squid esteja instalado em /usr/local/squid.
    Inicialize seu squid com o seguinte comando:
    Código :
    # /usr/local/squid/sbin/squid -d1
    Se der algum erro, poste aqui pra gente por favor.
    Padrão Nao mostra erro algum...
    O squid continua normal mas quando muita gente esta requisitando a conexao, ai eh o problema... frequentemente aparece que a URL nao pode ser exibida e a mesma msg aparece nos arquivos de log.
    Pq sera que quando aumenta o trafego acontece isso? Eh como se tivesse alguma opcao no squid.conf para aumentar o numero de processos ativos... pelo menos eh o que eu entendo pela msg de erro...
    Quantas pessoas estão penduradas no teu server .... ???
    Aumenta o teu "cache_mem 32 MB" para cache_mem 64 MB
    e vê melhora teu rendimento ...
    Flw ...
    valew meu velho, vou fazer a alteração e posto aqui...
    valew cara, o jeito foi aumentar o link mesmo... tinha muito usuario pra pouco link...
