Ae galera, instalei meu servidor radius, porem não esta autenticando, eu n sei mais o que faço para funcionar, eu executo ele em modo debug, e inicia blz, mais quando vou conectar da erro. Olhe:
rad_recv: Access-Request packet from host 192.168.10.1:42948, id=84, length=258
Service-Type = Framed-User
Framed-Protocol = PPP
NAS-Port = 120
NAS-Port-Type = Ethernet
User-Name = "iure@netexpress.com.br"
Calling-Station-Id = "00:19:21:8D:66:FC"
Called-Station-Id = "PPPoE-WinXP"
NAS-Port-Id = "Local"
MS-CHAP-Domain = "netexpress.com.br"
MS-CHAP-Challenge = 0xc74ceaf7d0b2c5514ce2a0d191e1833b
MS-CHAP2-Response = 0x01003ef5ea2cc2dd9309fc2d1edad45c3b140000000000000000c6cb688188e9e7c15379f1958dd1afb27abcb866208f5cdf
NAS-Identifier = "Eletron Luz"
NAS-IP-Address = 192.168.10.1
Mikrotik-Realm = "netexpress.com.br"
Processing the authorize section of radiusd.conf
modcall: entering group authorize for request 0
modcall[authorize]: module "preprocess" returns ok for request 0
modcall[authorize]: module "chap" returns noop for request 0
rlm_mschap: Found MS-CHAP attributes. Setting 'Auth-Type = mschap'
modcall[authorize]: module "mschap" returns ok for request 0
rlm_realm: Looking up realm "netexpress.com.br" for User-Name = "iure@netexpress.com.br"
rlm_realm: Found realm "netexpress.com.br"
rlm_realm: Adding Stripped-User-Name = "iure"
rlm_realm: Proxying request from user iure to realm netexpress.com.br
rlm_realm: Adding Realm = "netexpress.com.br"
rlm_realm: Preparing to proxy authentication request to realm "netexpress.com.br"
modcall[authorize]: module "suffix" returns updated for request 0
radius_xlat: 'iure@netexpress.com.br'
rlm_sql (sql): sql_set_user escaped user --> 'iure@netexpress.com.br'
radius_xlat: 'SELECT id, UserName, Attribute, Value, op FROM radcheck WHERE Username = 'iure@netexpress.com.br' ORDER BY id'
rlm_sql (sql): Reserving sql socket id: 4
rlm_sql (sql): User iure@netexpress.com.br not found in radcheck
radius_xlat: 'SELECT radgroupcheck.id,radgroupcheck.GroupName,radgroupcheck.Attribute,radgroupcheck.Value,radgroupcheck.op FROM radgroupcheck,usergroup WHERE usergroup.Username = 'iure@netexpress.com.br' AND usergroup.GroupName = radgroupcheck.GroupName ORDER BY radgroupcheck.id'
radius_xlat: 'SELECT radgroupreply.id,radgroupreply.GroupName,radgroupreply.Attribute,radgroupreply.Value,radgroupreply.op FROM radgroupreply,usergroup WHERE usergroup.Username = 'iure@netexpress.com.br' AND usergroup.GroupName = radgroupreply.GroupName ORDER BY radgroupreply.id'
rlm_sql (sql): User iure@netexpress.com.br not found in radgroupcheck
rlm_sql (sql): Released sql socket id: 4
rlm_sql (sql): User not found
modcall[authorize]: module "sql" returns notfound for request 0
modcall: leaving group authorize (returns updated) for request 0
Sending Access-Request of id 0 to 192.168.10.5 port 1812
NAS-Port = 120
User-Name = "iure"
Proxy-State = 0x3834
--- Walking the entire request list ---
Waking up in 6 seconds...
rad_recv: Access-Request packet from host 192.168.10.5:1814, id=0, length=244
NAS-Port = 120
User-Name = "iure"
modcall: entering group authorize for request 1
modcall[authorize]: module "preprocess" returns ok for request 1
modcall[authorize]: module "chap" returns noop for request 1
modcall[authorize]: module "mschap" returns ok for request 1
rlm_realm: No '@' in User-Name = "iure", looking up realm NULL
rlm_realm: No such realm "NULL"
modcall[authorize]: module "suffix" returns noop for request 1
radius_xlat: 'iure'
rlm_sql (sql): sql_set_user escaped user --> 'iure'
radius_xlat: 'SELECT id, UserName, Attribute, Value, op FROM radcheck WHERE Username = 'iure' ORDER BY id'
rlm_sql (sql): Reserving sql socket id: 3
radius_xlat: 'SELECT radgroupcheck.id,radgroupcheck.GroupName,radgroupcheck.Attribute,radgroupcheck.Value,radgroupcheck.op FROM radgroupcheck,usergroup WHERE usergroup.Username = 'iure' AND usergroup.GroupName = radgroupcheck.GroupName ORDER BY radgroupcheck.id'
radius_xlat: 'SELECT id, UserName, Attribute, Value, op FROM radreply WHERE Username = 'iure' ORDER BY id'
radius_xlat: 'SELECT radgroupreply.id,radgroupreply.GroupName,radgroupreply.Attribute,radgroupreply.Value,radgroupreply.op FROM radgroupreply,usergroup WHERE usergroup.Username = 'iure' AND usergroup.GroupName = radgroupreply.GroupName ORDER BY radgroupreply.id'
rlm_sql (sql): Released sql socket id: 3
rlm_sql (sql): No matching entry in the database for request from user [iure]
modcall[authorize]: module "sql" returns notfound for request 1
modcall: leaving group authorize (returns ok) for request 1
rad_check_password: Found Auth-Type MS-CHAP
auth: type "MS-CHAP"
Processing the authenticate section of radiusd.conf
modcall: entering group MS-CHAP for request 1
rlm_mschap: No User-Password configured. Cannot create LM-Password.
rlm_mschap: No User-Password configured. Cannot create NT-Password.
rlm_mschap: Told to do MS-CHAPv2 for iure with NT-Password
rlm_mschap: FAILED: No NT/LM-Password. Cannot perform authentication.
rlm_mschap: FAILED: MS-CHAP2-Response is incorrect
modcall[authenticate]: module "mschap" returns reject for request 1
modcall: leaving group MS-CHAP (returns reject) for request 1
auth: Failed to validate the user.
Delaying request 1 for 1 seconds
Finished request 1
Going to the next request
Ignoring duplicate packet from client mikrotik:42948 - ID: 84, due to outstanding proxied request 0.
Waking up in 1 seconds...
Sending Access-Reject of id 0 to 192.168.10.5 port 1814
rad_recv: Access-Reject packet from host 192.168.10.5:1812, id=0, length=24
Processing the post-proxy section of radiusd.conf
modcall: entering group post-proxy for request 0
modcall[post-proxy]: module "eap" returns noop for request 0
modcall: leaving group post-proxy (returns noop) for request 0
Delaying request 0 for 1 seconds
Finished request 0
Sending Access-Reject of id 84 to 192.168.10.1 port 42948
Waking up in 3 seconds...
Cleaning up request 1 ID 0 with timestamp 470770c9
Cleaning up request 0 ID 84 with timestamp 470770ca
Nothing to do. Sleeping until we see a request.
Me ajudem
