    Padrão Erro no spanassassin
    Esta dando esse erro quando inicio ele, e tem outros no log... alguem me ajuda por aqui??
    error: Can't locate Sys/Syslog/Win32.pm in @INC (@INC contains: /usr/lib/perl5/site_perl/5.8.7/i486-linux /usr/lib/perl5/site_perl/5.8.7 /usr/lib/perl5/5.8.7/i486-linux /usr/lib/perl5/5.8.7 /usr/lib/perl5/site_perl) at (eval 12) line 2.
    [24133] error: Can't locate Sys/Syslog/Win32.pm in @INC (@INC contains: /usr/lib/perl5/site_perl/5.8.7/i486-linux /usr/lib/perl5/site_perl/5.8.7 /usr/lib/perl5/5.8.7/i486-linux /usr/lib/perl5/5.8.7 /usr/lib/perl5/site_perl) at (eval 12) line 2.
    [24133] error: BEGIN failed--compilation aborted at (eval 12) line 2.
    [24133] info: config: failed to parse line, skipping, in "/etc/mail/spamassassin/local.cf": use_razor2 1
    [24133] info: config: failed to parse line, skipping, in "/etc/mail/spamassassin/local.cf": use_dcc 1
    [24133] info: config: failed to parse, now a plugin, skipping, in "/etc/mail/spamassassin/local.cf": ok_languages all
    [24133] info: rules: meta test FM_DDDD_TIMES_2 has dependency 'FH_HOST_EQ_D_D_D_D' with a zero score
    [24133] info: rules: meta test FM_SEX_HOSTDDDD has dependency 'FH_HOST_EQ_D_D_D_D' with a zero score
    [24133] info: rules: meta test HS_PHARMA_1 has dependency 'HS_SUBJ_ONLINE_PHARMACEUTICAL' with a zero score
    [24133] info: spamd: server started on port 783/tcp (running version 3.2.3)
    [24133] info: spamd: server pid: 24133
    [24133] info: spamd: server successfully spawned child process, pid 24135
    [24133] info: spamd: server successfully spawned child process, pid 24136
    [24133] info: prefork: child states: II
    outro erro:
    Oct 24 12:58:17 lobomau spamd[24135]: auto-whitelist: open of auto-whitelist file failed: locker: safe_lock: cannot create tmp lockfile /home/clamav/.spamassassin/auto-whitelist.lock.lobomau.link10.com.br.24135 for /home/clamav/.spamassassin/auto-whitelist.lock: No such file or directory
    Oct 24 12:58:17 lobomau spamd[24135]: spamd: clean message (2.9/4.0) for clamav:1035 in 6.9 seconds, 1628 bytes.
    Oct 24 12:58:17 lobomau spamd[24136]: spamd: connection from localhost [127.0.0.1] at port 33024
    Oct 24 12:58:18 lobomau spamd[24135]: spamd: result: . 2 - HTML_MESSAGE,RCVD_IN_XBL scantime=6.9,size=1628,user=clamav,uid=1035,required_score=4.0,rhost=localhost,raddr=127.0.0.1,rport=33023,mid=<[email protected]>,autolearn=no
    Oct 24 12:58:18 lobomau spamd[24136]: spamd: setuid to clamav succeeded
    Oct 24 12:58:18 lobomau spamd[24136]: spamd: processing message <[email protected]> for clamav:1035
    Oct 24 12:58:18 lobomau spamd[24133]: prefork: child states: IB
    ^X[24136] warn: auto-whitelist: open of auto-whitelist file failed: locker: safe_lock: cannot create tmp lockfile /home/clamav/.spamassassin/auto-whitelist.lock.lobomau.link10.com.br.24136 for /home/clamav/.spamassassin/auto-whitelist.lock: No such file or directory
    [24136] info: spamd: clean message (2.9/4.0) for clamav:1035 in 7.4 seconds, 1628 bytes.
    [24136] info: spamd: result: . 2 - HTML_MESSAGE,RCVD_IN_XBL scantime=7.4,size=1628,user=clamav,uid=1035,required_score=4.0,rhost=localhost,raddr=127.0.0.1,rport=33024,mid=<[email protected]>,autolearn=no
    Oct 24 12:58:24 lobomau spamd[24136]: auto-whitelist: open of auto-whitelist file failed: locker: safe_lock: cannot create tmp lockfile /home/clamav/.spamassassin/auto-whitelist.lock.lobomau.link10.com.br.24136 for /home/clamav/.spamassassin/auto-whitelist.lock: No such file or directory
    Oct 24 12:58:25 lobomau spamd[24136]: spamd: clean message (2.9/4.0) for clamav:1035 in 7.4 seconds, 1628 bytes.
    Oct 24 12:58:25 lobomau spamd[24136]: spamd: result: . 2 - HTML_MESSAGE,RCVD_IN_XBL scantime=7.4,size=1628,user=clamav,uid=1035,required_score=4.0,rhost=localhost,raddr=127.0.0.1,rport=33024,mid=<[email protected]>,autolearn=no
    Última edição por harrypotheard; 24-10-2007 às 11:55. Razão: Erro de dig
