Olà a todos.
Talvez alguem aki ja tenha passado por esta situação e sabe como resolve-la:
Tenho 2 servidores rodando H.A com drbd + heartbeat nestes servidores rodo os serviços de samba, dhcpd, postgres e tomcat, porem ontem para hj depois de 25 dias dos meus servidores ligados diretamente o servidor primario desligou por falta de energia e o servidor secundario teria que montar o serviço porem nao montou as partições e no heartbeat gerou o erro descrito abaixo:
ResourceManager[4613]: 2007/10/24_21:35:44 info: Running /etc/ha.d/resource.d/drbddisk start
ResourceManager[4613]: 2007/10/24_21:35:49 ERROR: Return code 20 from /etc/ha.d/resource.d/drbddisk
ResourceManager[4613]: 2007/10/24_21:35:49 CRIT: Giving up resources due to failure of drbddisk
ResourceManager[4613]: 2007/10/24_21:35:49 info: Releasing resource group: jacaranda.agrovale.com.br IPaddr::192.168.1.10 drbddisk Filesystem::/dev/drbd0::/sistema::ext3 Filesystem::/dev/drbd1::/backup::ext3 smb postgres dhcpd tomcat
ResourceManager[4613]: 2007/10/24_21:35:49 info: Running /etc/init.d/tomcat stop
ResourceManager[4613]: 2007/10/24_21:35:59 ERROR: Return code 1 from /etc/init.d/tomcat
ResourceManager[4613]: 2007/10/24_21:36:00 info: Retrying failed stop operation [tomcat]
ResourceManager[4613]: 2007/10/24_21:36:00 info: Running /etc/init.d/tomcat stop
ResourceManager[4613]: 2007/10/24_21:36:10 ERROR: Return code 1 from /etc/init.d/tomcat
ResourceManager[4613]: 2007/10/24_21:36:11 info: Retrying failed stop operation [tomcat]
ResourceManager[4613]: 2007/10/24_21:36:11 info: Running /etc/init.d/tomcat stop
ResourceManager[4613]: 2007/10/24_21:36:21 ERROR: Return code 1 from /etc/init.d/tomcat
ResourceManager[4613]: 2007/10/24_21:36:22 info: Retrying failed stop operation [tomcat]
ResourceManager[4613]: 2007/10/24_21:36:22 info: Running /etc/init.d/tomcat stop
ResourceManager[4613]: 2007/10/24_21:36:32 ERROR: Return code 1 from /etc/init.d/tomcat
ResourceManager[4613]: 2007/10/24_21:36:34 info: Retrying failed stop operation [tomcat]
ResourceManager[4613]: 2007/10/24_21:36:34 info: Running /etc/init.d/tomcat stop
ResourceManager[4613]: 2007/10/24_21:36:44 ERROR: Return code 1 from /etc/init.d/tomcat
ResourceManager[4613]: 2007/10/24_21:36:45 info: Retrying failed stop operation [tomcat]
ResourceManager[4613]: 2007/10/24_21:36:45 info: Running /etc/init.d/tomcat stop
ResourceManager[4613]: 2007/10/24_21:36:55 ERROR: Return code 1 from /etc/init.d/tomcat
ResourceManager[4613]: 2007/10/24_21:36:56 info: Retrying failed stop operation [tomcat]
Este script fiz de duas forma uma usando este material deste link abaixo:
Linux: Tomcat 5 em 10 comandos [Dica]
E o outro link fiz um bash chamando o startup.sh dentro do diretorio tomcat.
Desde ja agradeço.
Citação
