    Question Script DynDns não funciona !!!
    Olá galera do Under-linux !
    Criei um script no meu mikrotik que encontrei no site mas ele não funciona no meu mikrotik, nem ao menos starta !
    Criei no Gerenciador de Tarefas (Scheduler) o seguinte comando para startar o script:
    /system script run dyndns
    a regra no Scheduler starta normalmente, mas não executa o script nem ao menos ele starta.
    Segue abaixo o Script dyndns que coloquei no mikrotik: (Site = DynDNS -- Dynamic DNS, E-Mail Delivery and Other Services)
    :log info "DDNS: Begin"
    :global ddnsuser "usuario"
    :global ddnspass "senha"
    :global ddnshost "meu.dominio.com"
    :global ddnssystem ("mt-" . [/system package get [/system package find name=system] version] )
    :foreach int in=[/ip route find dst-address=0.0.0.0/0 active=yes ] do={
    :if ([:typeof [/ip route get $int routing-mark ]] = nothing ) do={
    :global ddnsinterface [/ip route get $int interface]
    :global ddnsip [ /ip address get [/ip address find interface=$ddnsinterface] address ]
    :if ([ :typeof $ddnslastip ] = nil ) do={ :global ddnslastip 0.0.0.0/0 }
    :if ([ :typeof $ddnsip ] = nil ) do={
    :log info ("DDNS: No ip address present on " . $ddnsinterface . ", please check.")
    } else={
    :if ($ddnsip != $ddnslastip) do={
    :log info "DDNS: Sending UPDATE!"
    :log info [ :put [/tool dns-update name=$ddnshost address=[:pick $ddnsip 0 [:find $ddnsip "/"] ] key-name=$ddnsuser key=$ddnspass ] ]
    :global ddnslastip $ddnsip
    } else={
    Uma abraço!
    kd o resto do script amigao ?
    :global ddns-user "xxx"
    :global ddns-pass "xxx"
    :global ddns-host "xxx"
    :global ddns-interface "xxx"
    :global ddns-ip [ /ip address get [/ip address find interface=$ddns-interface] address ]
    :if ([ :typeof $ddns-lastip ] = nil ) do={ :global ddns-lastip 0.0.0.0/0 }
    :if ([ :typeof $ddns-ip ] = nil ) do={
    :log info ("DDNS: No ip address present on " . $ddns-interface . ", please check.")
    } else={
    :if ($ddns-ip != $ddns-lastip) do={
    :log info [ /tool dns-update name=$ddns-host address=[ick $ddns-ip 0 [:find $ddns-ip "/"] ] key-name=$ddns-user key=$ddns-pass ]
    :global ddns-lastip $ddns-ip
    } else={
    obs.: onde tem essa carinha rindo eh "dois pontos p"
    so mais 1 coisa eu nao testei com dyndns so com changeip
    Última edição por masterbeto; 26-10-2007 às 20:49.
    Exclamation
    beto,
    mesmo assim nao funcionou.
    qual a placa interface que se coloca no campo :global ddns-interface "xxx" ?
    uso o mikrotik como roteador pppoe do adsl.
    tenho as interfaces:
    REDE WIRELESS = fornece internet à rede.
    LINK = busca internet no adsl.
    ROUTER = configuração do pppoe. (nao é placa de rede)
    Abraço.
    se vc usa o modem adsl em modo bridge poe a interface pppoe q disca pra conectar, se vc usa em modo router poe a interface q sai pro modem adsl
    Unhappy
    blza, coloquei aki e até mesmo criei uma conta no Changeip, mas ainda nao funciona.
    A questão é:
    o Script não está nem rodando no mikrotik, ele está parado.
    Owner: admin
    Last Time Started: "nada"
    Run Count: 0
    Quando clico em Run Script, é a mesma coisa que não fazer nada.
    Não sei o que há.
    Dá uma olhada em como vc configurou o seu no changeip, e me passa, passo a passo.
    valeu...
    Exclamation
    Descobri pq nao roda...
    Não tenho instalado as ferramentas avançadas..
    Como faço para instalar somente elas?
    Smile Changeip
    Olá, galera eu sofri até descobrir este aki !!!
    1º vai no site faça o cadastro link Enhanced Dynamic DNS Solutions
    system/script
    adiciona pelo winbox
    /tool dns-update name=DOMINIO ESCOLHIDO.changeip.org address=127.0.0.255 key-name=USUARIO DO SITE key="SENHA DO SITE"
    PRONTO SO CRIAR O AGENDAMENTO RODAR O SCRIPT
    system / schedule
    Lightbulb
    Funcionou !!!!!!!!!!!!!!!!!!!!!
    O script abaixo roda o domínio do site Enhanced Dynamic DNS Solutions .
    :global ddnsuser "YOURUSERID"
    :global ddnspass "YOURPASSWORD"
    :global ddnshost "YOUR.HOST.NAME.HERE"
    } else={
    } else={
    É somente criar o script e depois o agendamento da execução no Scheduler:
    /system script run "NOME DADO AO SCRIPT"
    Falou galera, agora é só curtir o acesso remoto a partir de uma rede externa !!!
