    Padrão Noise Level Qual A Taxa Ideal?
    Qual a taxa de NOISE LEVEL ideal para o perfeito funcionamento da pci wirelwss? Teoricamente seria o minimo, mas na pratica tenho visto diferente!
    tem q ficar por volta dos -90 a -100 .. pouco menos ou pouco mais que isso !!
    veja este treco de um texto
    If the noise level is very low then the system will be limited more by the receiver sensitivity than by the S/N ratio. If the noise level is high then it will be the Signal/Noise ratio that will count to achieve a given data rate. If the noise level is high we will need more received power. In normal conditions whithout any other WLAN on the frequency and whithout industrial noise the noise level will be around -100dBm. For example to achieve a 11 Mbps data rate with an Orinoco 802.11b card we would need a received power 16dB higher (S/N ratio) so a level of -100+16=-84 dBm but in fact the minimum receiver sensitivity is at -82 dBm...higher than -84. It means in that case the mimimum receiver sensitivity is the limiting factor for the system.
    nao .. nivel de ruído !!!
    ha um balanço entre SNR e noise level !! por causa da da sensibilidade do cartao... (vari ade cartao para cartao)..
