root@scut(8/15M)$msn-proxy -d -i -p -s -v
info: reading config file [/usr/local/etc/msn-proxy/msn-proxy.conf]
SQL: (SHOW TABLES)
SQL: (SELECT connect, save_msg, save_contacts, commands, internal_host FROM defaults LIMIT 1)
msn-proxy release : msn-proxy-0.7a [$Id: msn-proxy.h 112 2009-03-15 17:30:28Z loos-br $]
config file : /usr/local/etc/msn-proxy/msn-proxy.conf
default ns host : messenger.hotmail.com
default ns port : 1863
listen host : 0.0.0.0
listen port : 1863
backlog : 10
max clients : 1000
max ctl clients : 10
port range begin : 25000
port range end : 30000
ctl read timeout : 5
client read timeout : 600
client write timeout : 60
server read timeout : 600
server write timeout : 60
client connect timeout: 180
ACLs
connect : ALLOW
log messages : YES
save_contacts : YES
listen on [0.0.0.0:1863]
SQL: (DELETE FROM sb)
SQL: (UPDATE contacts SET contact_status = 'OFF', contact_deny = contact_deny & ~4194304)
SQL: (UPDATE users SET status = 'OFF')
debug: connection from [192.168.0.1]
connected to [messenger.hotmail.com:1863]
[(null)] send to ns server ==> VER 1 MSNP18 MSNP17 CVR0
[(null)] send to ns server ==> CVR 2 0x0416 winnt 6.0 i386 MSNMSGR 14.0.8064.0206 msmsgs [email protected]
SQL: (UPDATE users SET last_seen = NOW(), last_addr = '192.168.0.1' WHERE email = '[email protected]')
SQL: (SELECT contact_email, contact_dn, contact_uid, contact_status, contact_info, contact_flags, contact_flags2, contact_lists, contact_deny contact_chat FROM contacts WHERE email = '[email protected]')
SQL: (SELECT connect FROM users WHERE email = '[email protected]')
SQL: (SELECT save_msg FROM users WHERE email = '[email protected]')
SQL: (SELECT save_contacts FROM users WHERE email = '[email protected]')
SQL: (SELECT commands FROM users WHERE email = '[email protected]')
[[email protected]] send to ns server ==> USR 3 SSO I [email protected]
SQL: (INSERT INTO users (email, display_name, last_seen, last_addr, connect, save_msg, save_contacts, commands) VALUES ('[email protected]', '[email protected]', NOW(), '192.168.0.1', (SELECT connect FROM defaults), (SELECT save_msg FROM defaults), (SELECT save_contacts FROM defaults), (SELECT commands FROM defaults)))
SQL ERROR: (INSERT INTO users (email, display_name, last_seen, last_addr, connect, save_msg, save_contacts, commands) VALUES ('[email protected]', '[email protected]', NOW(), '192.168.0.1', (SELECT connect FROM defaults), (SELECT save_msg FROM defaults), (SELECT save_contacts FROM defaults), (SELECT commands FROM defaults))) MySQL: (Duplicate entry '[email protected]' for key 1)
debug: ns client pre command not accepted
payload: [(null)]
SQL: (UPDATE contacts SET contact_status = 'OFF', contact_deny = contact_deny & ~4194304 WHERE email = '[email protected]')
SQL: (UPDATE users SET status = 'OFF' WHERE email = '[email protected]')
debug: connection closed by ns server
debug: ns client disconnected
