  1. Agora vai o que eu acho que tem algum erro galera, se voce poderem analizar comigo e apontar meu erros ficaria muito grato.
    Adsl1 - 2 megas
    Adsl2 - 4 megas
    Adsl3 - 4 megas
    Obrigado
    Última edição por mktguaruja; 01-03-2010 às 13:20.
  2. /ip firewall address-list
    add address=200.155.80.0-200.155.255.255 comment=BRADESCO disabled=no list=loopback
    add address=200.220.186.0/24 comment=BRADESCO disabled=no list=loopback
    add address=200.220.178.0/24 comment=BRADESCO disabled=no list=loopback
    add address=64.38.29.0/24 comment=RapidShare disabled=no list=loopback
    add address=208.69.32.0/24 comment="" disabled=no list=loopback
    add address=208.67.217.0/24 comment="" disabled=no list=loopback
    add address=201.7.178.0/24 comment="" disabled=no list=loopback
    add address=201.7.176.0/24 comment="" disabled=no list=loopback
    add address=200.159.128.0/24 comment=BRADESCO disabled=no list=loopback
    add address=201.7.176.0/20 comment="Vdeos - Globo" disabled=no list=loopback
    add address=208.84.247.0/24 comment="Vdeos - terratv" disabled=no list=loopback
    add address=200.154.56.0/24 comment="Vdeos - terratv" disabled=no list=loopback
    add address=200.201.160.0/24 comment="Caixa Economica Federal" disabled=no list=loopback
    add address=200.201.166.0/24 comment="" disabled=no list=loopback
    add address=200.201.173.0/24 comment="" disabled=no list=loopback
    add address=200.201.174.0/24 comment="" disabled=no list=loopback
    add address=200.141.207.3 comment=Detran disabled=no list=loopback
  3. /ip firewall mangle
    add action=change-ttl chain=forward comment="Filtro tracert" disabled=no new-ttl=set:30 protocol=icmp
    add action=change-ttl chain=forward comment="Corta Tracert" disabled=no in-interface=wan1-pppoe new-ttl=set:30 protocol=icmp
    add action=change-ttl chain=forward comment="" disabled=no in-interface=wan2-pppoe new-ttl=set:30 protocol=icmp
    add action=change-ttl chain=forward comment="" disabled=no in-interface=wan3-pppoe new-ttl=set:30 protocol=icmp
    add action=accept chain=prerouting comment="Fora do Loadbalance" disabled=no dst-address-list=loopback in-interface=Local
    add action=mark-connection chain=input comment="Make the packet leaves via same interface" connection-state=new disabled=no in-interface=wan1-pppoe \
    new-connection-mark=wan1_conn passthrough=yes
    add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=wan2-pppoe new-connection-mark=wan2_conn passthrough=yes
    add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=wan3-pppoe new-connection-mark=wan3_conn passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=wan1_conn connection-state=new disabled=no new-routing-mark=to_wan1 passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=wan2_conn connection-state=new disabled=no new-routing-mark=to_wan2 passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=wan3_conn connection-state=new disabled=no new-routing-mark=to_wan3 passthrough=no
    add action=accept chain=prerouting comment="Assigning the propper routing-mark" disabled=no dst-address=192.168.0.0/24 in-interface=Local
    add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.0.0/24 in-interface=Local
    add action=mark-connection chain=prerouting comment="PCC Balance" disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan1_conn \
    passthrough=no per-connection-classifier=both-addresses:3/0
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan2_conn passthrough=yes \
    per-connection-classifier=both-addresses:3/1
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan3_conn passthrough=yes \
    per-connection-classifier=both-addresses:3/2
    add action=mark-routing chain=prerouting comment="Marking all the packets" connection-mark=wan1_conn disabled=no in-interface=Local new-routing-mark=to_wan1 \
    passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=wan2_conn disabled=no in-interface=Local new-routing-mark=to_wan2 passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=wan3_conn disabled=no in-interface=Local new-routing-mark=to_wan3 passthrough=no
    Última edição por mktguaruja; 01-03-2010 às 13:17.
  4. /ip route
    add check-gateway=ping comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=wan2-pppoe
    add check-gateway=ping comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=wan1-pppoe
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan1-pppoe routing-mark=to_wan1
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan2-pppoe routing-mark=to_wan2
    add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wan3-pppoe routing-mark=to_wan3
    add check-gateway=ping comment="" disabled=no distance=4 dst-address=0.0.0.0/0 gateway=wan3-pppoe
  5. Clovisfernando, só a título de informação, hoje existe no mercado placas PCI com até 4 saídas RJ-45 (quatro placas em uma), e com preço bem em conta, então caso vc coloque 2 placas dessa em um PC com 2 Slots PCI, vc já teria 08 interfaces de Rede.
Nome:	         DFE-580TX..jpg
Visualizações:	53
Tamanho: 	15,3 KB
    Outra coisa IMPORTANTE, citou "dificuldades para conseguir placas com pelo menos 4 PCI". Veja bem, geralmente essas placas com 4 PCIs, a mais comum encontrada no Brasil é a MiserASUS (ASUS). Me perdoe quem for fã, isso é uma opinião pessoal, na minha assistência técnica, o que mais tem é placa mãe ASUS bichada, todo mês trocamos pelomenos duas com os mesmos problemas. Infelismente isso acontece com muita frequencia por aqui, mas pode não ser o caso de vocês, mas o que vejo muito em Asus é nome e Preço Alto.
    Estou com o Mikrotik rodando em uma PC-Chips, Durom de 2.7GHZ, 2GB de RAM, com 150 clientes a mais de 3 anos, e até hoje nunca precisei mexer em nada a não ser atualizar e configurar.
    Quanto a qualidade das Routerboards é indiscutível, porque são produtos específicos para Mikrotik, mas como foi citado anteriormente, existem limitações.
    Fica registrada minha opinião.
    Boa Sorte a todos!
    Citação Postado originalmente por clovisfernando Ver Post
    Não sei se ainda dá tempo para opinar, mas vou reportar minha experiência. Tive diversos problemas como servidor PC-AP, principalmente devido a dificuldades para conseguir placas com pelo menos 4 PCI livres. Precisava de 4 conexões. depois de um problema que tive aqui de queima da placa mãe do server, acabei comprando uma RB-450G. Só alegria agora. tenho em torno de 40 clientes simultâneos em Hotspot e servidor de cache em paralelo rodando o Thundercache. Tudo tranqüilo, agora vou substituir meus PC-AP por RB-433.
    Ainda não tenho PCC, mas pretendo colocar RB-750.
  1. usando pop e smtp do provedor
    Por Itise no fórum Servidores de Rede
    Último Post: 02-01-2007, 16:40
  2. Página inicial do provedor
    Por renatoabaetenet no fórum Redes
    Respostas: 17
    Último Post: 25-12-2005, 10:01
  3. squid responde com dns do provedor
    Por acadori no fórum Servidores de Rede
    Último Post: 09-05-2005, 08:23
  4. Respostas: 2
    Último Post: 10-01-2005, 09:38
  5. Como obrigar o usuário a ver a página do provedor na hora da
    Por BrunoPiaui no fórum Servidores de Rede
    Último Post: 30-10-2002, 14:06
