  1. ola galera,....galera to muito agradecido e feliz de existirem pessoa como vcx q se dispoem a ajudar aqueles q ainda entao com pouco conhecimento. OBRIGADO! voltando ao assunto, eu fiz tudo como a primeira parte do video para fazer a configuraçao para modens em bridge! ate ai tudo bem, os modens em bridge e a rb ta balanceando bem mas varias veses durante o dia fika muito lento! espero q consigamos resolver esse pepino! valeu!
  2. Citação Postado originalmente por maninho03 Ver Post
    Mano da uma revisada ai se esta de acordo com estas regras ...essas sao do proprio geronimo utilizadas no video dele ...
    lembrando que estas regras sao para molden roteado
    /ip address
    add address=10.0.10.2/30 broadcast=10.0.10.3 comment="" disabled=no \
    interface=ISP1 network=10.0.10.0
    add address=10.0.20.2/30 broadcast=10.0.20.3 comment="" disabled=no \
    interface=ISP2 network=10.0.20.0
    add address=192.168.88.1/30 broadcast=192.168.88.3 comment="" disabled=no \
    interface=Local network=192.168.88.0
    /ip firewall mangle
    add action=accept chain=prerouting comment=\
    disabled=no dst-address=192.168.88.0/30 src-address=192.168.88.0/30
    add action=accept chain=prerouting comment="" disabled=no dst-address=\
    10.0.10.0/30 src-address=192.168.88.0/30
    10.0.20.0/30 src-address=192.168.88.0/30
    add action=mark-connection chain=prerouting comment=\
    connection-mark=no-mark disabled=no in-interface=ISP1 \
    new-connection-mark=ISP1_conn passthrough=yes
    add action=mark-connection chain=prerouting comment="" connection-mark=\
    no-mark disabled=no in-interface=ISP2 new-connection-mark=ISP2_conn \
    passthrough=yes
    add action=jump chain=prerouting comment=\
    connection-mark=no-mark disabled=no in-interface=Local jump-target=\
    policy_router
    add action=mark-routing chain=prerouting comment=\
    connection-mark=ISP1_conn disabled=no new-routing-mark=ISP1_trafic \
    passthrough=yes src-address=192.168.88.0/30
    add action=mark-routing chain=prerouting comment="" connection-mark=ISP2_conn \
    disabled=no new-routing-mark=ISP2_trafic passthrough=yes src-address=\
    192.168.88.0/30
    add action=mark-routing chain=output comment=\
    passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=ISP2_conn \
    add action=mark-connection chain=policy_router comment=\
    disabled=no dst-address-type=!local new-connection-mark=ISP1_conn \
    passthrough=yes per-connection-classifier=both-addresses:2/0
    add action=mark-connection chain=policy_router comment="" disabled=no \
    dst-address-type=!local new-connection-mark=ISP2_conn passthrough=yes \
    per-connection-classifier=both-addresses:2/1
    /ip firewall nat
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=ISP1
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=ISP2
    /ip route
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.0.10.1 \
    routing-mark=ISP1_trafic scope=30 target-scope=10
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.0.20.1 \
    routing-mark=ISP2_trafic scope=30 target-scope=10
    add comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=10.0.10.1 \
    add comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=10.0.20.1 \
    /ip dns
    set allow-remote-requests=no cache-max-ttl=1w cache-size=20480KiB \
    max-udp-packet-size=512 servers=8.8.8.8,8.8.4.4
  3. maninho03 fico feliz por você te conseguido fazer o seu loadbalance funcionar em bridge que é o melhor modo.
    Cara você já tentou pegar o modem e botar direto em um pc na hora que estiver tendo a lentidão pra ver se a lentidão é no loadbalance ou no seu proprio link pois se um dos links o modem estiver dando lentidão vai parecer que é no seu loadbalance pois isso aconteceu ontem aqui no provedor ontem a noite um dos modens ficou doido e teve cliente ligando para meu sócio ele olhou no loadbalance tinha um modem dando 14Kbps dai como a interface tinha conectividade o loadbalance não jogava os clientes para outro link assumir esses clientes mas ai só foi desligar o modem e pronto o problema foi solucionado na hora e hoje de manhã resetamos o modem e ele voltou ao normal batendo quase no talo de velocidade.
    E também aconteceu com um amigo aqui que vendi uma RB450 já configurada com loadbalance ele tinha um link e um modem que estava com problema e lentidão em um dos links dele por causa disso a internet ficou lenta mesmo com outro link funcionando normal dai tiramos o link e o modem ruim e deixamos o outro link assumir tudo a internet ficou 100% depois ele trocou o modem e resolveu o problema do link, agora ta funcionando normal,.
    fica dica ai pra você fazer os testes.
  4. ooo freitascs obrigadão pela dica amigo! vou fazer os testes aki pra tentar entender o ta acontecendo d errado! abraço!
  5. ooo freitascs obrigadão pela dica amigo... vou fazer os testes aki e tentar entender o q ta acontecendo de errado!abraço!
  1. Load balance pcc com links ip dinamico , como fazer?
    Por julinribeiro no fórum Redes
    Respostas: 21
    Último Post: 25-10-2017, 08:41
  2. Respostas: 35
    Último Post: 01-07-2016, 12:22
  3. Load Balance pcc com 3 links em bridge
    Por Auilker no fórum Redes
    Último Post: 27-05-2016, 11:46
  4. Respostas: 2
    Último Post: 26-09-2014, 10:41
  5. Load balance PCC nao funciona com AIEC.
    Por rubinhos no fórum Redes
    Último Post: 19-05-2010, 15:27
