    Padrão Configuração
    Galera dei um export na configuração dos cartoes, e estou postando aqui, espero que me ajudem.
    segue as configurações:
    # jan/24/2007 08:39:21 by RouterOS 2.9.39
    # software id = 1JLV-C00
    / interface wireless
    set water name="water" mtu=1500 mac-address=xx:xx:xx:xx:xx:xx arp=enabled disable-running-check=no radio-name="water" mode=ap-bridge \
    ssid="water" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2437 band=2.4ghz-b scan-list=default \
    rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=60 tx-power-mode=default noise-floor-threshold=default \
    periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled \
    wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled \
    default-authentication=no default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=pre-2.9.25 \
    hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=long compression=no \
    allow-sharedkey=no comment="" disabled=no
    set box name="box" mtu=1500 mac-address=xx:xx:xx:xx:xx:xx arp=enabled disable-running-check=no radio-name="box" mode=ap-bridge ssid="box" \
    area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2462 band=2.4ghz-b scan-list=default \
    basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=41 tx-power-mode=default noise-floor-threshold=default \
    set tower name="tower" mtu=1500 mac-address=xx:xx:xx:xx:xx:xx arp=enabled disable-running-check=no radio-name="tower" mode=ap-bridge \
    ssid="tower" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2462 band=2.4ghz-b scan-list=default \
    / interface wireless nstreme
    set water enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
    set box enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
    set tower enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
    / interface wireless manual-tx-power-table
    set water manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:\
    17
    set box manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17\
    set tower manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:\
    17
    / interface wireless security-profiles
    set default name="default" mode=none authentication-types="" unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" \
    wpa2-pre-shared-key="" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0="" \
    static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 \
    static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no group-key-update=5m
    / interface wireless align
    set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no \
    frames-per-second=25 audio-min=-100 audio-max=-20
    / interface wireless access-list
    / interface wireless snooper
    set multiple-channels=yes channel-time=200ms receive-errors=no
    / interface wireless sniffer
    set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name="" file-limit=10 \
    streaming-enabled=no streaming-server=0.0.0.0 streaming-max-rate=0
  2. #8
    Galera eu consegui resolver o problema.
    Troque os cartoes que estavam no server, tirei os D-Link AG 530 e coloquei cartao senao com chipset prism... pelos testes que estamos fazendo aqui, nao tive mais o problema, eu recomendo o uso desses cartoes e descartem os
    D-Link, só dor de cabeça
  3. #9
    ola amigo blz . aonde vc encontro estes cartao ? esse cartao e o cb3 ?
  4. #10
    Acho que condenar os AG530, seria muito presipitado, poderia ser configuracoes que por default sao diferentes nos cartoes prism e atheros.
  5. #11
    olá amigo...usamos ag 530 aqui em 5.8 e nunca tivemos problema algum...temos alguns problemas com g 510..mas ae em 2.4..
    como disse o amigo acima acho q é cedo descartar a dlink..
    mas blz....qq coisa poste ae..
    t+ e bom trabalho..
  6. #12
    ola pessoal .. to presisando de cartao senao ..alguem sabe aonde encontra ?
