Postado originalmente por
ederamboni
name="xxxxxxxxnet4" mtu=1500 mac-address=xxxxxxxxxxxxxxxx arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="xxxxxx.net4" mode=ap-bridge ssid="inforcel.net4" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2417 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=26 tx-power-mode=card-rates
noise-floor-threshold=127 periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=net4
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=long
compression=no allow-sharedkey=no
essa e as conf com alteracoes e vou manda abaixo de outra placa que ta perfeita
1 R name="xxxxxxxxxx" mtu=1500 mac-address=00:xxxxxxxxx84 arp=enabled
radio-name="xxxxxxxxxx" mode=ap-bridge ssid="xxxxxxxxx" area=""
frequency=2422 band=2.4ghz-b/g scan-list=default rate-set=default
54Mbps
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
max-station-count=2007 ack-timeout=dynamic tx-power=30
tx-power-mode=all-rates-fixed noise-floor-threshold=127
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-b wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=net3 disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=long compression=no
allow-sharedkey=no
